Taller Sidewall to improve MPG?
Old Jun 13, 2010 | 12:10 AM
Sagittarius30's Avatar
Sorry I tried searching for the past hour but didnt find my specific question.
Anyway, I have a 07 Fit Sport and I was told if I use 195/60/15, I can see slightly better MPG if I were to use stock size?
I've searched around and saw mixed opinion. Some said it takes more energy to get the bigger wheel spinning but others said the bigger wheel actually covers more ground thus using less effort.
Just like to know whats the most accurate answer.
Thank you!!
Old Jun 23, 2010 | 12:57 PM
No body has any insight to this?
Old Jun 23, 2010 | 01:15 PM
Krimson_Cardnal's Avatar
Plug in all pertinent data into this: Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
You'll be looking at the circumference. Simply put, if your choice has a larger circumference than the OEM then you will improve GPM.
However, that's not the whole story.
Go to Tire Rack and do some searching on rolling resistance. Then go into the Eco-Fit Discussion group in these forums and search around. The topic has been covered endlessly.
Madasadad
Apr 19, 2013 06:16 PM
THE_CRUCK
May 11, 2012 06:11 PM
Foxjordan22
Feb 11, 2011 09:57 AM
davela72
Mar 13, 2008 01:15 PM
Charles Lasitter
May 4, 2005 04:44 PM
