Rear Bumper Removal . . . ?
Old Jul 8, 2010 | 12:23 AM
Marrk's Avatar
The shop manual says that this is a two-man operation.
Has anyone removed the rear bumper on an '08 Fit? Is it a one-man or two-man deal?
Any other rear bumper removal advice is welcome.
Thanks.
Old Jul 8, 2010 | 04:17 AM
setter11's Avatar
One man Operation...
2 Screws [Phillips head] one located inside each rear wheel well...
2 Allen Bolts located on either side right inside the hatch opening
After all are taken off gently pull
Old Jul 8, 2010 | 12:50 PM
Marrk's Avatar
Thanks, setter.
I've got the shop manual and I understand about the bolts, screws and clips. What I don't exactly get is the "gently pull" part. The boys over at the s2k forums say that s2k bumper removal, which is similar to the Fit, requires quite a yank. I wish I had an image, or an idea, of what kind of fastener I was yanking apart. Obviously, it is some kind of push in-pull out deal, but I fear breaking something.
Again, thanks.
Old Jul 8, 2010 | 02:04 PM
gd3vbp's Avatar
You can do this on your own. Even after doing this a few times I still get nervous, but I've found that if you start at the rear fender and pull the side of the bumper out, standing next to the car pull straight towards you, after you see how thats clipped in, you'll have a feel for it.
Old Nov 13, 2010 | 08:48 AM
kbh's Avatar
kbh
I just replaced the rear bumper cover myself. At least on my Fit Sport, there are also two expansion clips on the underside of the car near the tow hook. Overall pretty easy to remove and reinstall. The rear spoiler is attached to the cover with four screws -two at each end in the wheel well area, two small nuts at the corners, and five expansion clips along the length
Old Dec 18, 2010 | 08:48 PM
solbrothers's Avatar
this. rear bumper removal is super easy, definitely a one man operation. also i do realize that this thread was bumped by a spammer
aysia
Apr 27, 2015 04:23 PM
Merriweather
Mar 25, 2014 09:05 AM
ALLDAYKK
Aug 9, 2013 10:11 PM
JohnnyAction
Mar 14, 2012 11:35 PM
