Oil Filter relocation kit $59.00 S/H included
Old Jul 11, 2010 | 08:15 PM
Perrenoud Fit's Avatar
Just for your info....
Maybe be able to use a filter with more capacity.
Old Jul 11, 2010 | 08:26 PM
SilverBullet's Avatar
Have you used one before? Wont the oil drain out of the lines and have a dry start? I am just curious, I think thats cool and will lower oil temps too.
Old Jul 11, 2010 | 08:32 PM
Texas Coyote or Kelsodeez would be a better source to answer that. But I will check and get back here 2U.
Old Jul 11, 2010 | 11:23 PM
FITMugen's Avatar
IMHO, it is not neccessary for Honda FIT since it is quite easy to reach the oil filter. If it is Civic Si (8th Gen), may be worth it.
Old Jul 12, 2010 | 12:29 AM
Texas Coyote's Avatar
I want one... It is exactly what I need to hook up an oil cooler oil pressure and temperature gauge. A sandwich type adapter could be used to mount a second filter to be able to change one and replace the oil mid way between changes and get 25% more protection....Filters have check valve to prevent flow when the engine isn't running and I think the engine may also have one as well.... Let me see if I can find space for everything and if you don't mind I 'd like to know where it is available from.
Old Jul 12, 2010 | 02:48 AM
jagass's Avatar
This looks cool man. I think I need this.
Old Jul 12, 2010 | 03:04 AM
kelsodeez's Avatar
UNBANABLE
just a little fyi, the greddy oil filter relocation kit didnt fit on my L15. the oil pan side didnt fit because it was too fat. i wonder if this brand does. also, when putting one in, you want it to sit as close to level with the stock oil filter location as you can.
Old Dec 1, 2010 | 01:56 PM
mgutt's Avatar
Any alternative to Greddy available? I really want that, but I don't trust china crap.
Old Dec 1, 2010 | 02:34 PM
DiamondStarMonsters's Avatar
Great find Mike! I was hoping we had this option.
This^ is precisely what I had in mind as well, especially if I have to run engine oil through a turbo's hot CHRA and then dump hot oil it back into the pan, I'd rather send it through a cooler first.. I am looking at a large 12,000GVWR cooler from Hayden, like I have on the race car.
Old Dec 1, 2010 | 02:43 PM
mgutt's Avatar
Found this manufacturer:
Think Automotive Ltd On line shop
Maybe these parts fit.
Old Dec 1, 2010 | 02:54 PM
Are those -6AN or -8AN fittings on the OFH?
Old Dec 27, 2011 | 07:22 AM
HoSDo's Avatar
Guys, I got a question on this topic although it's quite old!
I'd like to buy a relocation kit not for the FIT but for the other car I've got home which however uses the same filter (m20x1.5, 66 mm diameter). Clearences on the other engine is quite low, could fit at most a 68/70 diameter take off plate. What is the ext diameter from this take off plate? Is there someone that could measure it?
J N Winkler
May 21, 2016 11:11 AM
JDMxGE8
124
Feb 15, 2015 10:14 AM
Odie
28
Apr 4, 2013 01:43 PM
lcq4blackstar
Sep 3, 2011 06:25 PM
azncarbos
Feb 5, 2008 01:45 AM
