Running Goodridge SSBB lines
Old Aug 3, 2010 | 03:16 PM
mole177's Avatar
Upgrading to them are well worth it.
still on stock pad/rotor.
braking has vastly improved.
next step is to flush dot three to dot four.
Old Aug 3, 2010 | 04:28 PM
Santiad's Avatar
is this a hard DIY?
Old Aug 3, 2010 | 04:50 PM
zer0sk8ordie's Avatar
Nice. I need to try these.. My brakes suck I have ebc pads and rotors
Old Aug 3, 2010 | 05:39 PM
jadr09fit's Avatar
Upgrading brake fluid isn't worth it unless you track the car, or do very aggressive canyon carving. Plain old DOT 3 stops much heavier vehicles than the Fit every day just fine. Even then, the only fluid really worth upgrading to is DOT 5.1 (NOT 5, as the 5 will destroy your brake lines!).
Old Aug 3, 2010 | 10:41 PM
cr4zy3lgato's Avatar
How about the install? don't you have to flush and bleed to change lines? I was thinking on doing that next summer...
Old Aug 4, 2010 | 04:49 AM
mole177's Avatar
Arrow
I do not feel dot 3 is good enough.
i baked my dot 3 fluid (stock) after 1 canyon run on my old car. brake fade blows.
Old Aug 4, 2010 | 04:54 AM
mole177's Avatar
SSBBL is 1 step above (difficulty level) changing rotors, not pads.
i didnt have a power bleeder, so i did old school and had a friend use foot power to bleed, no flush needed.
the only special tool needed is a flared wrench, all other normal tools. standard screwdriver and sockets.
Old Aug 4, 2010 | 05:03 AM
bmxman's Avatar
hmmm...maybe you had brake fade because it was on an old car and the brake fluid needed to be replaced. I agree with what was previously posted. There really isn't a valid reason to go to dot 4....but hey it's your time and money do what you want!
Old Aug 4, 2010 | 05:26 AM
Type 100's Avatar
Why not DOT4? It's just fluid; it's not as if it's going to cost you an arm and a leg over DOT3. Better braking (in this case, higher fluid boiling point) is always a good investment.
mole177,
How much did the Goodridge lines cost you?
Old Aug 4, 2010 | 01:49 PM
dewthedew's Avatar
I need to get around to do this to my fit.
Old Sep 16, 2010 | 07:21 PM
Sparco Fit's Avatar
what size flare wrench do you need?
yovtecjustkickedin
Mar 5, 2017 11:35 AM
yovtecjustkickedin
Dec 27, 2016 08:48 AM
phenoyz
Apr 17, 2015 11:18 PM
dbcmaster
Aug 26, 2011 03:55 PM
chibitul
Jul 28, 2005 10:30 AM
