Max wattage 09 Fit can take for subs
Old Aug 14, 2010 | 10:40 AM
Teh_tourist's Avatar
I put some new subs in my 09 fit sport, but my subs are cutting off once I get to a certain volume. It may be to some bad wiring but I want to make sure it's not my car. I've got a 500Watt RMS Mono amp, can the stock alternator power this?
Old Aug 15, 2010 | 09:17 AM
SiXiam's Avatar
If it cuts off, it is likely the amp overheating or not being able to handle that much wattage. A capacitor will help dimming headlights, but not a cut out.
500 watts shouldn't be a problem for the car, but it depends on how much you are drawing for your other speakers & accessories. I have a walmart amp, that can't handle high volume. The cheaper amps typically lie about their max rms rating. Mine is a 4 channel, but I can only run two speakers or it keeps cutting out.
Old Aug 15, 2010 | 10:36 AM
britdevine's Avatar
Sounds like bad wiring or maybe a bad amp to me
FyrFytr
Apr 10, 2012 12:46 PM
OhNineFIT
Oct 16, 2010 10:59 AM
sageman
Jan 16, 2010 08:16 PM
setter11
Sep 29, 2009 10:55 PM
jaebee
Aug 31, 2008 08:17 PM
