Brake light comes on during hard cornering
Old Aug 23, 2010 | 09:55 PM
Wolfvision's Avatar
I autox'ed this weekend and on my 4th run the Fit started throwing a the BRAKE light when i was cornering hard. For about 2 days afterward the light would also come on when the handbrake was all the way down and i could deactivate it but placing a beer cap under where the handbrake met the console to elevate it slightly. It has ceased doing this but still under hard cornering the light will pop on and beep. Anybody have this experience? Thanks
Old Aug 24, 2010 | 05:35 PM
Carbuff2's Avatar
AutoCross or RallyCross?
No matter...
the BRAKE indicator could be coming on because of the handbrake lever/switch OR the brake fluid reservoir switch.
If it's the reservoir, you may be low on brake pad. Fill the fluid A LITTLE BIT but check out pad thickness at the first opportunity.
Old Aug 29, 2010 | 07:48 PM
Wolfvision's Avatar
AutoX actually even though that pic is from a rallyx. I got 45k on the clock and original pads so i would think its time to refill my brake pads.
Old Apr 5, 2011 | 05:33 AM
NickHimSelf's Avatar
I was told that if the brake fluid is low it will also turn. Have you checked that?
Old Apr 5, 2011 | 12:08 PM
apexanimal's Avatar
this can happen... generally as your pads wear, the fluid level goes down as it has more "space" to press...
but also check pad thickness...
Old Apr 5, 2011 | 12:48 PM
Krimson_Cardnal's Avatar
^^agree^^ Check pads first. If needing replacement do it before topping off fluids. apeanimal points out why. I'm thinking there's a bit of wear on the rears as well. Parking brake lever should not be that loose. How many clicks before it's doing its job.
sailorman2439
Oct 2, 2016 04:43 PM
chinkyy
Mar 4, 2013 10:37 AM
AppleMac*Fit
Nov 14, 2010 01:40 PM
subhamoy@gmail.com
Jun 18, 2005 10:17 AM
mmdir2002@yahoo.co.uk
May 18, 2005 02:25 AM
