CR-Z 6-speed in a Fit?
Old Aug 25, 2010 | 01:55 PM
Tofuman's Avatar
Since the CR-Z uses a form of an L15 Fit engine, I wonder if the 6-speed manual transmission from the CR-Z could bolt up to a Fit... Food for thought.
Old Aug 25, 2010 | 02:21 PM
grtpumpkin's Avatar
I bet it would, but what are the external dimensions of the gearbox? And, more important, what are the ratios in the 6spd?
Old Aug 25, 2010 | 03:08 PM
hondaFORlife's Avatar
I wondered about this as soon as I heard it was available with a 6speed.
Old Aug 25, 2010 | 03:25 PM
Slimjimx701x's Avatar
Could not find the final gear....
Gear ratios
1 3.142
2 1.869
3 1.303
4 1.054
5 0.853
6 0.688
R 3.307
EDIT: final gear 4.11
Old Aug 25, 2010 | 04:39 PM
kenoshainflames's Avatar
it might work. crzforum.com check there. i just bought a cr-z with the 6-speed.
Old Aug 25, 2010 | 04:43 PM
Tofuman's Avatar
Just gotta wait for one to crash or get rearended so i can find a used transmission!
Old Aug 25, 2010 | 05:41 PM
kelsodeez's Avatar
UNBANABLE
it will not work. unless you cut off the bell housing on your tranny and weld it onto the crz tranny. the power assist connection is right there through the bellhousing. i had a chance to tinker with the konig crz. its a pretty cool car, but the only things i really saw that were swappable are the suspension components.
Old Aug 26, 2010 | 12:15 AM
angryfit's Avatar
well disk brakes in the rear would be a worth swap!
Old Aug 26, 2010 | 10:27 AM
your probably right but according to the owner book i have the assist motor is attached to the block not the tranny. either way im sure it wont work because of the assist motor.
Old Aug 26, 2010 | 04:50 PM
kelsodeez's Avatar
UNBANABLE
what i saw was a large diameter wire lead with orage casing that plugged directly into the bellhousing. even if the actual assist motor is mounted onto the block behind the flywheel or in front of it, a custom flywheel would have to be made for it in addition to the bellhousing from the fit being welded onto it. i would really like to crack one open one day to see whats what.
Old Aug 26, 2010 | 08:49 PM
FITMugen's Avatar
You would get 5 lug wheels as well but you have to swap both front and rear.
Old Aug 26, 2010 | 09:47 PM
Type 100's Avatar
Hmmm, doesn't the IMA electric motor on the CR-Z exist where the transmission would be? That might complicate things (that's an understatement).
Old Aug 27, 2010 | 02:23 PM
its between the block and bell-housing.
Old Aug 27, 2010 | 06:22 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
i don't see it working but i do see the disc brakes might have a good chance.
Old Aug 28, 2010 | 09:31 AM
ill take some pictures of the owners book today and post them
Old Aug 28, 2010 | 12:07 PM
polaski's Avatar
Wouldn't this make the Fit slower off the line? Those are much taller ratios.
Old Aug 30, 2010 | 11:42 AM
Tofuman's Avatar
Here is a picture of the Spoon Sports CR-Z racecar getting it's engine/transmission installed...
Old Sep 8, 2010 | 02:53 PM
Old Sep 8, 2010 | 03:44 PM
Tofuman's Avatar
Looks like the next MMC Fit (2011) will have a 6-speed in the 1.5 RS model in Japan. That one should be a direct fit. Hopefully we get a 6-speed in the US - it would be a lot cheaper to source a used transmission without shipping overseas.
ragingti
Car Shows, Events, and Racing
Aug 7, 2012 04:38 PM
vwli
Sep 1, 2011 10:55 PM
mahout
Oct 13, 2010 07:08 AM
2Legit2Fit
Sep 1, 2010 10:05 PM
Padraic
Jun 30, 2010 05:39 PM
