Mishimoto Intake Bolts fell off (oops)
Old Aug 28, 2010 | 02:59 PM
R2D2's Avatar
I was changing my spark plugs today and noticed that my Mishimoto intake was just hangin' loose in the engine bay! The bracket pieces are still attached to the carbon fiber air chamber part, but the bolts and nuts that used to attach to the car must be somewhere on I-275.
Nuts and bolts are easy enough to replace but I was also using the factory air box rubber bushings. Anyone have a part number for those?
Also, do yourself a favor and check all the bolts on your mods every once in a while.
-R2
Old Aug 29, 2010 | 02:16 PM
gynosis's Avatar
happened to me as well, make sure the bolts and nuts are on tight otherwise the engine vibrations slowly work them loose.
Old Aug 29, 2010 | 03:05 PM
Cyril1972's Avatar
And god invented Loctite.........
Old Aug 29, 2010 | 03:20 PM
R2D2's Avatar
@Cyril1972 Hmm... Loctite... there's a thought. But would that make it too hard to remove if I ever wanted to part it out.
@gynosis So did you lose the rubber bushings too, like I did? If I can't source them from Honda, I might have to replace them with a stack of washers instead. :|
-R2
De36
Aug 9, 2023 10:45 PM
Leets
Oct 24, 2010 08:34 PM
tanukifit
Jul 28, 2009 05:01 AM
GD3 FTW
17
Feb 16, 2009 02:50 PM
xonexlifex
Oct 27, 2008 01:17 AM
