Where to order tail light cover?
Old Aug 31, 2010 | 04:23 PM
Killgore9998's Avatar
Hi folks,
I'm a complete newbie when it comes to car issues, so I'm sorry if this question is stupid.
I recently cracked and broke off the cover of one of my tail lights on my 2009 Fit Sport. I understand that replacing the cover should be easy to DIY, but I don't know where to order a replacement cover.
So far all I've been able to find are entire tailight replacement modules. I don't need all that, however, as the bulb works fine, etc. I just need to replace the cover.
Any recommendations?
Thank you in advance!
Old Aug 31, 2010 | 04:34 PM
Goobers's Avatar
I don't think the tail lights are sold like that.
As far as I know, they're sold as whole housings.
The "easy to DIY" usually refers to opening up an existing housing to smoke (darken) it, then put it back together.
Old Aug 31, 2010 | 04:39 PM
I see.
I guess that replacing the entire tail light would not be so easy to DIY?
I guess I should probably just take it to a body shop then.
Old Aug 31, 2010 | 04:49 PM
Btrthnezr3's Avatar
Replacing the tail light is EASY. It's like pop a panel on the inside, 3 bolts, 3 clips and bam, it's out...then reverse.
Please don't take it to a body shop just to replace the tail light...they will RAPE you.
Buy one off ebay--or if it's cheaper, buy a set of aftermarket tails...it is soooooo easy to change. 30 minutes...tops for both sides.
Old Aug 31, 2010 | 04:54 PM
Awesome. Thank you so much for your help, sir. Hopefully I don't screw up and buy the wrong one. =P
Old Aug 31, 2010 | 05:03 PM
Goobers's Avatar
Sorry, I didn't mean to imply it was hard, I only meant that any DIYs you might've found about opening up the housings for just for that, opening the housings (not replacing individual parts).
Swapping out the tail light for a new housing is an easy DIY too, just like Btrthnezr3 said.
The part number for the standard tail lights are:
33500-TK6-A01 (right side)
33550-TK6-A01 (left side)
So hopefully, if they claim to be OEs on ebay, they'll list part #s.
Myorangefit
Jan 3, 2021 02:59 AM
ONEDVSMOFO
Aug 31, 2012 01:49 AM
Killgore9998
Sep 2, 2010 03:41 AM
dave clark
Nov 5, 2008 08:36 PM
dave clark
Oct 30, 2008 11:18 AM
