Under the Hood Lighting for the 1K time haha
Old Sep 14, 2010 | 09:05 PM
Perrenoud Fit's Avatar
Talking Under the Hood Lighting for the 1K time haha
Okay this is my 1st DIY thread with that said Here we go......
Materials - LEDs from Hong Kong no others can be bought as cheap. 25 blue single LEDs were 6.00 shipped, 30cm blue strips 5 for 15.00 shipped. So I looked around under the hood and chose the plastic strip over the radiator and drilled 3/16" holes for just the 5mm LED to push through and stay very well. this lit the front up pretty good if I were to do it again I just use strips. The back of the engine was dark and untill I saw FELIX'S SC Fit I figured a strip was used under the tower brace. Now for the 3.00 it cost the back of the engine is kick'n!
The power came from the fuse/relay block by the battery (GD3) through a 2 amp weather proof fuse holder then to a small spst switch from Radio Shack, the wiring is just a series circiut, the ground can be made were ever is the most convient for your application. The hood light is a single really bright chip(closeup) in pix, all in all there are 26 LEDs for this project.
This is some of the lights the black length is the 30cm strip and the plastic bag are collars for the LED single for a nice clean look.
In this pic are the dif. switches and a 3 fuse holder. 22ga color coded speaker wire works well and is Cheap the amp load is nil on the LEDs and the colr keeps the ground and pos. know while running the circuits.
Here's were the power is coming from (red wire) and it goes to the fuse holder (the black cover).
Here is were the on/off switch is place by the headlight in front of the grill.
And here's the Rice!
On a scale of 1-10, difficulty 5, amount of time 7, money 2
Enjoy and post some pix
Mike
Old Oct 25, 2010 | 03:02 PM
Vizibelli's Avatar
I can only see the last two pictures of the final result.
Old Oct 25, 2010 | 07:00 PM
ya the pix have been deleated due to lack of space on my albums.
Old Oct 25, 2010 | 09:36 PM
Vizibelli's Avatar
Upload pics to imageshack.us
roksta
Sep 17, 2023 09:41 AM
FELIXY69
Oct 7, 2022 12:48 PM
Xtina
Oct 14, 2015 10:59 PM
Macswfc
28
Sep 3, 2015 04:00 AM
Ritzbury
Oct 17, 2007 01:26 PM
