check gas cap message
Old Sep 20, 2010 | 03:23 PM
vickenp's Avatar
Hi guys,
ever had a check gas cap message show up, where the computer display is? I saw this the first time today.
2009 fit lx in canada
I confirmed the cap was securely tight with a few clicks
Old Sep 20, 2010 | 04:18 PM
Black3sr's Avatar
Ignore it. After a few cycles of engine being off and on it will go away. I had it earlier this year. It is common. Not to worry.
Old Sep 20, 2010 | 04:39 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
when it happens to me i just take it off and put it back
on again. note: while car is off.
then i restart it and it goes away.
Old Nov 8, 2010 | 09:52 AM
Blackbeard's Avatar
Smile Wow...
Filled up this weekend, then drove my daughter to her soccer game in the middle of nowhere (40+ miles)...like a dork I forgot to put the cap back on, and did not notice it until we got to her game. I was surprised no warning light came on with the gas cap dangling on the side of the car...
Old Apr 9, 2011 | 02:02 AM
Codger01's Avatar
Just had this pop up tonight when leaving work. I was thinking of pulling the neg battery cable for few mins to re set the ecu. I now think I will wait a few start cycles to see if it goes away. But I will have to go pick up new headlight bulbs... the pass side one is out!!
Old Apr 9, 2011 | 02:38 AM
JJIN's Avatar
instead of a message my cel came on when my gas cap was loose.
Old Apr 9, 2011 | 03:52 PM
Codger01's Avatar
Message was gone when I went down this am to get the new headlight bulbs.
Old Oct 25, 2011 | 05:13 PM
Jennag's Avatar
Me too!
Hi-
I had the same thing happen with mine- my husband filled up my 2008 fit with gas, then drove home (only a few miles) with the gas cap hanging open (grrrr...). Later, when I got in the car, I noticed it and tightened it. A couple of days later I noticed a "loose gas cap" message and once again made sure that the cap was on tightly (it was). Now my engine light is on. I checked the manual and it says that this will happen after a loose gas cap and to give it several days to reset itself. It's been over 3 weeks and the engine light is still on- does anyone out there know what's going on and what I should do?
Old Oct 25, 2011 | 07:20 PM
raytseng's Avatar
Originally Posted by Jennag
Hi-
If you think the car is fine, you can reset the ECU.
Either borrow a reader to read then clear the code (some parts stores will loan out tools with creditcard deposit like autozone)
Loan-A-Tool® Program | In Our Stores | AutoZone.com
Or just detach the battery for about 15min, and that usually will clear it too.
If CEL come back on AFTER being cleared, you better see what the code is really about.
Old Oct 26, 2011 | 08:29 AM
Jennag's Avatar
Thanks raytseng
I'll try detaching the battery for a bit to see if that does the trick. Thanks!
Old Oct 26, 2011 | 08:55 AM
mhadden's Avatar
Hi-
If it's been that long, you may want to have your gas cap pressure tested. It may be bad...
ztyhurst
Jul 8, 2012 09:06 AM
wk406
Canada Fit Forums & Clubs
40
Jan 11, 2012 02:51 PM
rlhannan
May 4, 2009 02:06 PM
seizure
Jan 27, 2008 10:26 AM
smeister
Feb 19, 2007 06:40 PM
