Fuel milliage meter
Old Sep 23, 2010 | 08:35 AM
Hirotirta's Avatar
Fuel milliage meter
Hello,does anyone know where I can fuel milliage meter that can read fuel consumption and how many kilometers that I can drive with fuel in tank.thank you...
Old Sep 23, 2010 | 11:16 AM
Fit4Trav's Avatar
I think you're looking for a scangauge.
Old Sep 23, 2010 | 05:35 PM
grtpumpkin's Avatar
Yep, the Scangauge will do that. Just be aware that you need to be fastidious in your resetting of the mileage and fuel used when you fill up or the readings will be worthless. The one thing I don't like about my SGII is that it defaults at 60 miles to empty and won't read any lower.
Old Oct 12, 2010 | 12:19 AM
Bster13's Avatar
how does the scangauge better your MPF vs. the 2009+ fit's MPG sliding scale meter?
Old Oct 12, 2010 | 06:29 AM
Type 100's Avatar
Not 100% sure on this but the fuel consumption gauge on stock GE Fits reportedly over-reads by a few MPG.
Can the ScanGauge be calibrated somehow to avoid this?
Old Oct 13, 2010 | 03:10 PM
Bster13's Avatar
The 2009 Honda Fit has a TSB for overly optimistic MPG Meter:
Fit MPG
Once fixed, users have reports much more accurate numbers.
So I understand the Scanguage type of devices can read ODBII and obtain a lot of info on engine fault codes and what not, but in terms of reporting back on real-time MPG for hypermilers, is it any better than the Fit's MPG Meter (if it is working correctly)?
Thanks!
Old Oct 13, 2010 | 05:57 PM
Krimson_Cardnal's Avatar
Don't have a scan gauge but use GarminHD in a similar way and I find that compared with the 2010 Fit mpg info they are both within 1-2 mpg.
I have trust in the Fit's MM info.
AppleMac*Fit
Aug 1, 2024 11:53 AM
lmatthew9
Aug 29, 2008 11:03 AM
cdphillips60
Sep 19, 2006 03:26 PM
knutcrai
May 21, 2006 05:26 PM
mav
Jan 20, 2006 08:03 AM
