ROTA J-MAG (Candy Tone blue) Questions
Old Oct 18, 2010 | 06:03 PM
MaxSoul's Avatar
Question ROTA J-MAG (Candy Tone blue) Questions
Hi which wheel , will fit my fit better?.
16x7 4x100 +40mm offset 67.1mm
16x7 4x100 +40mm offset 73mm
Yip they'r the same wheels.. just different sizes ;i guess...
Help me!! cause i dont know much about offset, size ,etc ....
My Car : GE8 Sport 2010
Old Oct 19, 2010 | 01:28 PM
MaxSoul's Avatar
Pls Guys tell me Whats the difference between 67.3 n 73 ?? i dont wanna make any mods to my fender, spacer, etc
Old Oct 20, 2010 | 09:43 AM
!bungle's Avatar
The 67.1mm and 73mm measurements are the hub bore diameters. That's the size of the hole in the center of your wheel. Factory wheels are 56.1mm hub bore. You will need hub centering rings (aka hub-centric spacers, etc.) to make up the difference in size. Most wheel retailers have them, they're cheap. So, either size is fine. Here's a link explaining more:
How Hub Centric Rings Work - JustForWheels.com
Old Oct 20, 2010 | 11:47 AM
GD3_Wagoon's Avatar
^^winner
just as an fyi, j-mags are HEAVY wheels. i was getting 38-40mpg easy on my gd3 with 15x7 slips (205/50/15) then that got knocked back to 28-30 with the 16x7 j-mags (205/45/16). gotta admit though, j-mags are good looking wheels... i wish i could afford legit m7's though lol
Old Oct 20, 2010 | 12:19 PM
MaxSoul's Avatar
Exclamation
Originally Posted by GD3_Wagoon
^^winner
ty for the info , i dont want them to slow down my car- ... in that case... ill just save money for my mugens : however that will take me forever!
Old Oct 20, 2010 | 06:51 PM
!bungle's Avatar
This site:
Rota Weights
Shows a 15x7 J-Mag weighing 13lbs. Factory Honda Fit Sport Alloys in 16x6 weigh over 19lbs. Everythings relative!
Sure, I'd rather have Mugens, but I wouldn't spend that much on wheels for my daily driver myself. Gotta think of replacement costs in the event of theft or pothole/curb damage, etc. Also all the other trick bits I could buy with the difference. Uh, and daily crap like rent/food/cable/phone/blah-blah-blah.
Sorry, I know it's a tired old debate, "real" vs. "fake", but look at the wheel weights mentioned for the Mugen M-7 in these posts:
http://www.wheelweights.net/wheel-weight-weight.pdf shows J-Mag & M-7 at 13.0lbs each, which seems to be the consensus...
http://www.audiworld.com/tech/wheel22.shtml (mentions M-7 brittleness?)
Mugen wheel weight? - Honda-Tech post #6 (also mentions M-7 brittleness?)
Wheel Weights/Size/Make Specs (Hundreds of them) - Honda-Tech post #1
►ULTIMATE wheel weight guide!!!◄ - EK9.org JDM EK9 Honda Civic Type R Forum post #7
Usually, forged is much better than cast, but I think the center is the only forged portion of the Mugen M-7, whereas the rim is spun. Yeah, I know the Rota is cast... most "fake" wheels are, but it's light enough (at 6lbs better than stock) and I doubt the O.P. is planning on clippin' chicanes on his way to a faster lap-time at the local racetrack.
Could be wrong, though. Am a lot. Also, drinking NOS all day makes me wander through the web researching way too much just to make a point!
Have fun everyone, and buy Mugens! or Rotas! or whichever you really want, 'cause it's your ride, not mine. I'm stuck between Enkei RPF1s, Rota Slips, TRM C1s, 5zigen FN01R-Cs, or Rota R-Specs... I might never be able to decide.
Old Oct 20, 2010 | 07:37 PM
GD3_Wagoon's Avatar
i don't know the validity of those weights but then again my j-mags were 16's not 15's.
when i pulled off the gd3's oem alloys then lugged over the j-mags there was a significant weight difference. i didn't have a scale but my skinny arms told me the j-mags were heavier lol
Old Oct 21, 2010 | 01:40 AM
krakhed's Avatar
if you wanna keep it light, look at the weight of tires too (but that will take time)
i know my feathers were waaaay lighter in 15's then the 16's so i went that option. i think the weight jumped from 15 to 16 on every wheel i looked at.
Old Oct 26, 2010 | 09:07 PM
MaxSoul's Avatar
ty
ty for the info guys , however if i take 15' x 7 instead of those 16' x 7 - what would be the consequences? for a GE8 ( 2010 Fit Sport )
Old Oct 27, 2010 | 06:03 PM
!bungle's Avatar
TireRack lists tire weights by size. Since you should go for the same overall diameter for continuity of gearing, fuel economy, ride height, and speedo/odo readings - 205/55/15 matches the stock 185/55/16 the best.
Since the stock tires are skinny, they weigh around 18lbs. The lighter 205/55/15 tires weigh around 19lbs.
Use the comparison feature at TireRack's site by picking a size and then check the compare box, then look at weights - some weigh as much as 22lbs, so it's worth looking at prior to making a decision.
HTH,
Fuzzyfunk
22
Mar 9, 2023 09:40 PM
littleblackcar
Oct 18, 2013 04:35 AM
cFoo
Jan 26, 2011 12:16 PM
hanzo
Feb 6, 2010 06:40 AM
Lunar_GD3
Dec 14, 2007 03:35 PM
