Tire newbie. Will these Fit?
Old Nov 28, 2010 | 08:10 PM
ElectricD's Avatar
Hello,
I'm purchasing new tires and wheels for my 2007 Fit DX. The OEM tires are 14". I've been hearing stories about tires rubbing and not fitting in the wheel well, so I'm not quite sure about the wheels I've chosen, I hope someone has some insight for me
Will these fit?
Tires: 205/45ZR16
Wheels:16x7
Thanks!
Old Nov 28, 2010 | 08:20 PM
Hootie's Avatar
They will fit provided that the wheel's offset is no lower than +42 (+41 or lower will rub) at factory hieght and no lower than +45 (+44 or lower will rub) when lowered.
Old Nov 28, 2010 | 08:30 PM
ElectricD's Avatar
Just checked and the offset is 42mm.
I feel better knowing they will fit, but sounds like I am cutting it close..
Thanks for your quick reply!
Old Nov 28, 2010 | 08:36 PM
ElectricD's Avatar
Oh, wait, I didn't notice the significance of the '+'. Mine are just 42. not +42. Should I reconsider these wheels?
I found this thread and I think I will be ok since my car isn't lowered:
https://www.fitfreak.net/forums/fit-...-included.html
Old Nov 28, 2010 | 09:26 PM
Hootie's Avatar
It shouldn't a difference between +42 and 42 since they both mean positive 42. The only worry would be if it had a negative dash/minus sign like this for example. -42
If you are still sketchy on getting these wheels, ask the place you're buying them from if the offset is a positive 42 millimeters (+42 mm). As long as it is not a negative number you are good.
Old Nov 29, 2010 | 01:09 AM
ElectricD's Avatar
Thanks again for your help!!
Old Nov 29, 2010 | 01:10 AM
Hootie's Avatar
No problem. Just curious though, what wheels do you plan on getting?
Old Dec 5, 2010 | 08:08 PM
ElectricD's Avatar
Nothing fancy, just wanted to get rid of the plastic hubcaps and needed some new all seasons.
16x7 Silver w/Machined Lip Focal F09
205/45ZR16 Continental ExtremeContact DWS
Goettler
60
Jun 29, 2016 10:41 PM
Sleep_DEPRIVED
Nov 15, 2009 03:54 AM
braziers
Jan 30, 2009 05:51 AM
peenutz_fit
Jan 18, 2009 05:28 PM
Tiffany
Apr 16, 2008 04:46 PM
