Tire newbie. Will these Fit?
Hello,
I'm purchasing new tires and wheels for my 2007 Fit DX. The OEM tires are 14". I've been hearing stories about tires rubbing and not fitting in the wheel well, so I'm not quite sure about the wheels I've chosen, I hope someone has some insight for me
Will these fit?
Tires: 205/45ZR16
Wheels:16x7
Thanks!
Will these fit?
Tires: 205/45ZR16
Wheels:16x7
Thanks!
Oh, wait, I didn't notice the significance of the '+'. Mine are just 42. not +42. Should I reconsider these wheels?
I found this thread and I think I will be ok since my car isn't lowered:
https://www.fitfreak.net/forums/fit-...-included.html
It shouldn't a difference between +42 and 42 since they both mean positive 42. The only worry would be if it had a negative dash/minus sign like this for example. -42
If you are still sketchy on getting these wheels, ask the place you're buying them from if the offset is a positive 42 millimeters (+42 mm). As long as it is not a negative number you are good.
Goettler
60
Jun 29, 2016 10:41 PM
peenutz_fit
Jan 18, 2009 05:28 PM
