rota fitment
Old Dec 2, 2010 | 06:43 PM
hondafituk's Avatar
rota fitment
4x100 et40 16x7
or
4x114 et40 16x7
which is the right one for the gd jazz/fit dont want wheels to stick out etc.
also will tein springs lower it enough for a decent ride hight.with out catching
and last one what tyre size would u recommend
Old Dec 2, 2010 | 07:48 PM
solbrothers's Avatar
you should search before buying anything. there is a lot of information on this website.
Old Dec 2, 2010 | 07:50 PM
lungfish23's Avatar
That's just the bolt pattern.
You need 4x100
Offset is 40 so you should be ok with a 205/45/16 tire. Or something close to that.
Old Dec 2, 2010 | 08:59 PM
!bungle's Avatar
Using an offset of 45mm would provide less chance of rubbing, especially with lowering springs. you could use 205/45/16 tires with that offset. You may be able to avoid rubbing using a narrower/lower overall diameter tire than the one I mentioned if you must stick with the 40mm offset wheels.
Old Dec 3, 2010 | 01:47 AM
hondafituk's Avatar
ok thanks think im better of with the buddy club wheel running a 42 offset
mikeGe82012
May 28, 2017 12:11 AM
jamalridesbikes
Feb 14, 2014 02:03 PM
tokenasianguy69
13
Sep 2, 2010 01:11 PM
jazz_do_it
Feb 14, 2010 09:09 AM
ezekiel_771
Jul 12, 2008 07:03 PM
