help!! on HKS F-CON IS tuning
Old Dec 11, 2010 | 10:34 AM
ngng123's Avatar
hi guys,
I just installed the hks turbo kit on my car along with hks f-con is piggyback, the problem is that when i go full throttle, the drive by wire thing on the car seems to close the throttle body, so the car blogg down. I am having a professional shop installed the kit, the shop owner saids that he installed a few of them and that didn't happen before. So I am pretty sure that the ETC is affecting some us who are going turbo or supercharge, anyone here has that problem before? any solution to that?
any input is welcome
Thank you in advance
Old Dec 12, 2010 | 02:58 AM
DiamondStarMonsters's Avatar
Do you have the TPS voltage logged? How do you know the throttle plate is shutting?
How did you determine you aren't just knocking, leaking post turbo on the intake or pre-oxygen sensor on the exhaust side? or overrunning the MAP?
Have you removed the throttle controller and found the problem went away?
Old Sep 7, 2011 | 07:03 AM
BlackPearlFIT's Avatar
hks makes a turbo kit for the GE?
im confused...
if so please inform me
Old Sep 7, 2011 | 09:49 AM
this is one of few threads where i see people saying they have a hks turbo kit for their GE, just not seeing where the kit comes from...
Old Sep 8, 2011 | 09:03 AM
BUMP for my unknown question: hks makes a turbo kit for the GE?
Old Sep 8, 2011 | 09:22 AM
TunaDaMan's Avatar
Old Sep 8, 2011 | 11:35 AM
i read/replied to your other post.
but to keep things on topic to this thread...
does any one know of any F-Con tuners near ohio?
Old Sep 8, 2011 | 01:17 PM
TunaDaMan's Avatar
To the OP, I know having the car on and engine off is different from driving the car around, but at least you can check to see what your throttle body is doing, just take off the intercooler piping connecting to the throttle body and have someone step on your throttle to check that it is operating correctly.
Or the easier way without taking the piping off, just check the TPS through a scantool such as the scangauge, ultragauge or one of the many that connects to a laptop, such as scantol
If you think your ETC is the problem, you can also test your car with the ETC and without to see if that affects your TB/bogging issue in any way.
Old Sep 25, 2011 | 11:26 PM
myblackhatch's Avatar
did you ever figure out the problem? i would be interested to know..
fluid
64
Jul 23, 2014 10:03 AM
1990hondahf
Jul 7, 2009 12:25 PM
RXMOTORS
34
Nov 15, 2008 10:34 AM
200psGD3
19
Feb 17, 2008 12:07 PM
southwilrise87
May 8, 2006 12:14 AM
