Car makes sizzle noise after turning off car
Old Jun 15, 2006 | 12:54 AM
nexus4400's Avatar
Anyone experience this? I noticed that my car makes a faint hissing/sizzling noise right after I turn it off. It seems like the noise is resonnating from the Alternator or AC Compressor. Anyone notice this? Also, could condensation from the AC line cause this? My AC line always leaks water (condensation) onto my ABS system.
Old Jun 15, 2006 | 01:35 AM
triggerzer0's Avatar
try running with out the A/C, and then see if it still does it when you cut it off.
the way you are describing it, it does indeed sound like an AC related deal. keep in mind the AC lines have a high pressure and a low pressure side, when the car isnt running, the two sides have a tendancy to want to equalize pressure. It's also possible that the noises you hear are condensation from the un-insulated parts of the AC lines dripping down onto hot parts under the hood, like exhuast manifolds, the brakes, transmission, the engine intself.
Either way, it's likely harmless, but if you're worried about it, take it into your service department and have them check it out while it's still under warranty in case it actually is a gremlin
Old Jun 15, 2006 | 02:20 AM
Paulo107's Avatar
yeah my car does the sizzle sound...sounds normal to me
Old Jun 15, 2006 | 01:31 PM
stacey14's Avatar
mine kind of shudders after i shut it off and take my feet off the clutch and brake. i guess that's normal, though.
lief101
Apr 22, 2017 05:34 PM
illissus
Feb 24, 2017 12:57 AM
D50boy
Oct 1, 2015 06:50 AM
Freemananana
Aug 7, 2015 09:02 AM
myblackhatch
Nov 12, 2011 12:45 AM
