Fogs died
Old Dec 24, 2010 | 07:28 AM
konespeed's Avatar
Fogs died
Hey guys,
The crack in right fog light apparently got so bad that water got in them. Now none of the fogs turn on. Does this mean the fuse is blown? or just get new fog light housing and bulbs and i'll be good?
And also do you guys have recommendations on where to get new fog housings? thanks for the help guys.
kevin.
PS: I'm broke so somewhere not super expensive.
Old Dec 24, 2010 | 12:45 PM
Hootie's Avatar
There is a possibility that you've blew a fuse that you can try checking that. If you have a digital voltimeter, check the resistance in your bulbs. Hopefully its the bulb itself that has an open circuit, the number on the meter will fluctuate if it is (it'll stay a constant 0 if they aren't blown).
If the bulbs check out, you'll need a wiring diagram to locate the proper test points to check the resistance in the connectors and harness for the fog lights.
As for the fog housing, if I recall correctly the housing is the same as the one for the RSX (towlie had RSX ion fogs IIRC) and the 8th Gen Civic. Be sure to double check though and if they are the correct ones just need to swap the plastic cover with your Fit's. You should be able to find them on ebay or another forum.
Old Dec 24, 2010 | 12:49 PM
chrisng's Avatar
if yours was like mine, i think from being lowered my bumper hit driveways too much and acutally sheared through the bulb connector on one side. i still have the ohter side if you are in need of a replacement bulb.
Old Dec 24, 2010 | 02:20 PM
Fat Ping Cat's Avatar
i took all of the glass off the housings and used lexan for the lenses (impact resistant plexiglass) $8 from lowes. I used black RTV adhesive to seal the lexan to the housing
I did this yesterday, works nice
Old Dec 24, 2010 | 02:55 PM
konespeed's Avatar
Thanks for the input guys, Fat ping cat, could u possibly take pics? I might do that today! that sounds like a great idea!
Old Dec 24, 2010 | 03:50 PM
I'm definitely not taking the fogs out again, I'm sick of doing that, I had three sets of housing in there and glass cracked on all of them. I just traced the housing onto the protective film then used a dremel with a reinforced cut off wheel to cut and shape the lexan. I put a thick bead of adhesive RTV around the edge, removed the one side of protective film and pressed the lexan to the housing. I secured the lexan with tape and let the RTV cure for 24 hours. Then I took the tape and the film off and put another bead of RTV around the edge to ensure a seal. Cure for 24 hours then install.
Old Dec 24, 2010 | 09:41 PM
konespeed's Avatar
Wow that looks great! thanks man, i'll get on that as soon as i can!
When you say cure, just let it dry right?
Old Dec 24, 2010 | 09:47 PM
accordguyintake's Avatar
^dude EPIC DIY mod right here... super props
Old Dec 25, 2010 | 11:54 AM
thanks, it kind of irritates me that honda uses glass on the fogs yet the actual headlights are made out of plastic
and yep, let it dry well before installing
2007Fit5AT
Jul 27, 2013 05:58 PM
HKittyFit
Apr 22, 2012 11:22 AM
FITMEEE
Jan 6, 2011 04:03 AM
OneStopCustoms
Jan 10, 2008 01:36 AM
Mugen_Dom
Oct 4, 2006 01:50 PM
