Heated Mirrors in Canada cost $70 each
Old Dec 28, 2010 | 10:54 AM
Black3sr's Avatar
plus tax. I just called my dealer.
Wiring should be easy as they operated off same switch as rear window defog.
Old Dec 28, 2010 | 11:09 AM
jcuecker's Avatar
Is this in CAD or USD? Also is this for the entire mirror and housing? Does it have a winker? Is this a power folding mirror?
Thanks!
Old Dec 28, 2010 | 12:40 PM
milanojazz's Avatar
yes more info please, these things are a necessity
Old Dec 28, 2010 | 01:45 PM
Black3sr's Avatar
Cdn dollars + HST (13%)
Glass only. When I had mine apart to add the winkers covers there were two wires coming from a built in/attached heating element on the back of the glass.
As far as wiring I am assuming they attach to the rear window defogger wiring as both operate off the same switch.
Old Dec 28, 2010 | 04:28 PM
neil patrick harris's Avatar
IIRC, a US member here said that the insight's heated mirrors would work on our FITs. i'm not certain if he was speaking of the mirror (glass) or the entire housing.
Old Dec 28, 2010 | 09:54 PM
FITMugen's Avatar
Yes, 09-11 Honda Insight heated side mirrors will work with 09-11 Honda Fit. However, mirror holder is a little bit different. You have to reuse Honda Fit mirror holder. Otherwise, you have to order heated side mirrors for Canadian.
Heated side mirrors are just 2 wire connection to rear defogger.
Old Dec 30, 2010 | 12:14 AM
jnesselroad's Avatar
website where we can pick a set up?
Old Dec 30, 2010 | 06:01 AM
Black3sr's Avatar
College Hills Honda Parts
Can't tell if those are heated or not. Would likely need the harness as well.
The whole mirror looks to be $200+. I wonder if we have wiring for winkers built in? I doubt it.
seedee
May 24, 2016 10:12 AM
ncoflin
Jul 27, 2015 10:34 AM
david223
Aug 15, 2013 11:30 AM
NewFitGuy09
18
Oct 1, 2012 08:01 PM
YeeFit
Apr 3, 2008 02:30 PM
