Throttle body coolant hose for temp
Old Feb 2, 2011 | 02:23 AM
astig's Avatar
Question Throttle body coolant hose for temp
i want to install a water temp gauge but do not want to cut into my newly installed silicone radiator hose for the probe.
i plan to do the throttle body bypass mod and have a t-fitting for the probe. does this coolant line have a shut off valve? if so where is it and can i get rid of it?
or any other suggestion on where i can tap the probe?
Old Feb 2, 2011 | 07:10 PM
DOHCtor's Avatar
Do the same thing i did! Install a Scangauge 2 in your car, it will give you data on ECT, IAT, Spark Advance, etc.... Minus the PITA to install all those gauges, route wires, be creative on sensors placement, etc!
160$ on Ebay!!
Marko!!
Old Feb 3, 2011 | 02:17 AM
astig's Avatar
already have the gauges installed and the lines laid out... only the water temp is left...
Old Feb 3, 2011 | 11:55 AM
DOHCtor's Avatar
The best would be to try it and watch with a scangauge or obd2 scantool if it matches the temps of the ECT sensor and, if not, place it elsewhere!
Marko!!
bensenvill
26
Dec 23, 2014 04:39 PM
Myxalplyx
Dec 19, 2014 10:15 AM
mxl180
Sep 21, 2014 10:38 PM
MIAMIFIT
Dec 21, 2009 06:44 PM
DOHCtor
Jan 9, 2009 09:46 PM
