Where to put your sunglasses
Old Feb 6, 2011 | 04:38 PM
Brain Champagne's Avatar
I found that my sunglasses fit perfectly in the gap above the steering column, between the column and the dashboard. Here's a photo:
http://www.brainchampagne.com/Comedy/FitSunglasses.jpg
(when I clicked on the link the photo was huge, but when I cut and pasted the url into a new browser window it's normal-sized, I don't know why)
Note that I have my steering wheel as far lowered as it goes, and that every pair of sunglasses is different so yours might not fit. I took some sharp turns and they seem to stay- they fit well, like a can in a cupholder, but only upside-down, not right-side-up.
Some caveats:
1. Don't accidentally try to raise the steering wheel, or you'll crush your glasses. You may remember, but a fat parking attendant might not realize what's there, try to raise the wheel, and...
2. If you reach for them through the steering wheel while the car is moving and you try to turn, you won't be able to because your arm's in the way. May seem obvious but it's not something you're likely to be thinking about if you're reaching just as someone cuts in front of you...
3. It's a very visible location- if you have expensive sunglasses it's something to think about.
Old Feb 7, 2011 | 11:37 AM
jdubatl's Avatar
I always keep mine in the space in front of the 2 cupholders in front of the gear shift....
Old Feb 7, 2011 | 12:20 PM
Btrthnezr3's Avatar
I have one of those visor clips from Target--holds them in place and out of the way
Old Feb 7, 2011 | 12:33 PM
I used to keep them by the cupholder but since they bounced around there I had to keep them in a case- farther away and less accessible. On the column they're right there.
Next thing I have to do is to cut a piece of cardboard in the shape of the gap between the sun visors so that when the sun is directly in front of me I can slide it in place. I wish they made the visors wider...
Old Feb 7, 2011 | 12:41 PM
Krimson_Cardnal's Avatar
Here's a trick: Shark Bite
Old Feb 7, 2011 | 01:17 PM
Btrthnezr3's Avatar
Yup...that looks exactly like mine, Krimson.
Old Feb 7, 2011 | 01:50 PM
MikePDaTruth's Avatar
A friend of mine works at TD Bank and gave me about 15 of those visor clips for free Does the job just fine.
I've tried putting them in the bin in front of the gearshift, but they're a little bit of a reach to get to them in there.
Old Feb 7, 2011 | 03:26 PM
kenmei's Avatar
mine are in their case which goes in the driver side door pocket
don't wanna risk a broken window over some sunglasses
Old Feb 7, 2011 | 11:38 PM
susanlynn7's Avatar
Mine ride in the driver's door too.
zeniitti
Aug 31, 2017 03:34 AM
wackyflik
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
16
Jun 17, 2017 07:32 PM
sschoe2@gmail.com
Jun 7, 2017 12:42 PM
fidget247
May 30, 2011 03:33 PM
msoulier
Oct 1, 2010 04:17 PM
