Sub work up
Old Feb 12, 2011 | 01:57 AM
Gffy2334's Avatar
Sub work up
Here is the work template for my re-install of my system.
I had my wife help me with the approximate placement, we both decided symmetry would look best. so I measured out everything and made my placement markings, and calculations.
The subs are Soundstream Stealth 13's with a bottom mount depth of only 2 inches. The inner depth of the box will be 3.5 inches and will give me about 0.82 sq ft of sealed airspace per subwoofer.
The idea is to flush mount everything, including the Amp and Cap for use of the cargo space without damaging the equipment.
This build will go down tomorrow, and hopefully finished over the weekend.
***the following link is for my previous build with all of the same hardware.***
https://www.fitfreak.net/forums/fit-...rner-subs.html
Last edited by Gffy2334; Feb 13, 2011 at 11:36 PM. Reason: added link for reference.
Old Feb 13, 2011 | 11:35 PM
Gffy2334's Avatar
Here is the work I did so far between yesterday late afternoon, and most of today.
As you can see, I have it pretty much together. I still have to seal the top side up as much as I can then work on fine tuning some of the fitment around the joints.
I quit for the day when I realized my sanding sponge wasn't gonna cut it (pun intended) and cleaned up, took the wife to a movie, and bought a Rasp on the way home to get through the shaping a little faster.
The enclosure is only 3.5 inches deep at the most, and if you look, you can see that the recessed mount for the Sub is 3/4 inch mdf. all together I still have near .7 sq ft for each sub, and should sound great.
Please post any questions/ suggestions you might have.
-Marty
Old Feb 15, 2011 | 09:17 PM
lashlee's Avatar
It looks like a good start! Just make sure you seal up the enclosure!
Old Feb 21, 2011 | 02:56 PM
chunkylover8200's Avatar
i wanna see how this comes together!
Old Feb 26, 2011 | 05:41 PM
Mr08FiT's Avatar
looks good man
Old Feb 26, 2011 | 11:09 PM
Perrenoud Fit's Avatar
Nice work looks solid shouldn't rattle & good choice I like a ice cold RC meself!
1SickVeilsideZ
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Jul 3, 2013 02:44 PM
JDMchris.com
Jul 8, 2012 02:59 AM
Vash
Dec 15, 2011 09:52 AM
britdevine
15
Oct 22, 2011 04:24 PM
drock305
Apr 18, 2010 12:59 PM
