help?
Old Feb 19, 2011 | 10:37 PM
danng's Avatar
help?
my driver side headlight just stop working. i installed HID about 2 weeks ago. i've check the fuses and and the light bulb nothing is burnt out. does anyone have any suggestion of what the problem is? thanks!
Old Feb 19, 2011 | 10:57 PM
azncarbos's Avatar
Check your connection. And what fuse did you check? And check your grounding too.... do had other stuff connected to the battery?
Old Feb 19, 2011 | 11:06 PM
Fitting's Avatar
MIght be the hid ballast. Swap the ballasts.
Old Feb 22, 2011 | 04:47 AM
08_Nick_Fit's Avatar
I had a similar problem, I was told to switch sides with the ballasts to see if the problem travels with the ballasts, my problem was fixed with a new harness, I guess my harness was bad. But check all connects first.
Old Feb 22, 2011 | 05:29 PM
danng's Avatar
so the problem was the ballast. thanks everyone!
Old Feb 22, 2011 | 05:56 PM
junior40er's Avatar
What brand are you using? I'll make sure to stay away.
Old Feb 22, 2011 | 06:41 PM
danng's Avatar
i bought some o-nex. but the person i bought it from was really cool. i just called him and he replace the ballast for free.
ej20i
Apr 17, 2011 10:31 PM
Yoshi11289
Jan 3, 2011 11:05 PM
Jumarcil
Nov 4, 2009 09:22 PM
L-Bear
Sep 3, 2009 03:12 PM
kodo
19
Jan 24, 2009 12:49 PM
