wear holes in carpet
Old May 4, 2011 | 07:23 AM
Juliane's Avatar
Damn the thin carpet in our Fits! I have 2 spots where the carpet has actually worn through...One on the passenger side where that part of the gas tank sticks up, my son uses it for a footrest; the other is where the mat in my footwell has rubbed against it (non-original mats I guess). So I have 2 white spots in a car barely 3 years old! Suggestions? They're not in places that are covered by mats.
Old May 4, 2011 | 10:00 AM
sooznd's Avatar
Mine had a worn spot on the tranny hump, driver side. I had less than 11,000 miles and had the car less than a year. Dealer said they had never seen this before But they would replace it under warranty.
I just had it replaced last week. I am now getting the Weather tech digital mats & hope it will help a bit--although the worn spot is higher then the edge of the weather tech mat.
I realized it is the way I get out of that created the worn spot. I am making a conscious effort to get out of the car with both feet on the mat instead of my usual launch with right foot at edge of the trans hump. Check with your dealer to see if your car may still covered
Old May 4, 2011 | 10:45 AM
Texas Coyote's Avatar
I have thought of snatching the seats and carpets out and having the whole floor of the car cover in spray on bed liner when ever my carpets become a problem. I have seen a cargo van and a couple of jeeps done that way and it isn't bad looking... It quiets things down, is easy to clean, doesn't hold odors from dogs or sweaty fat people and will never wear out... You can also drill holes an install removable drain plugs and empty a bag or two of ice on the floor to stay cool on those hot summer afternoons while driving home from work in rush hour traffic.
Old May 4, 2011 | 11:44 AM
Hootie's Avatar
Two words, black sharpie.
I've had a hole in the carpet behind my dead pedal for about year now. I just marked up the white sound deadening with the sharpie and ignored it. I hate that its falling apart that easily but I'd rather do that than risk having a tech/upholstery person damage something or cause any new rattles from something not being reinstalled properly.
Old May 4, 2011 | 11:54 AM
If I had a black car a sharpie would solve a lot of the cosmetic flaws that have been incurred.
Old May 4, 2011 | 07:55 PM
Juliane's Avatar
That's a pretty low-tech solution Hootie!
Old May 4, 2011 | 07:57 PM
Juliane's Avatar
I can see doing that...What kind of weight does that add? And how much does it cost? Hootie's solution costs -0-
Old May 5, 2011 | 12:04 AM
kbri's Avatar
Get some flexible carpet and pop it in there - I got some from miamicorp.com - got the ozite superflex black and redid the whole floor. It works really easily, you only need to make like three cuts in the footwell area to get it to lay nicely. You can use spray adhesive (they've got stuff for $10 that worked well) to stick it to your stock carpet. Tuck the edges at the console and along the door, done. I got 4 yards of the 80" wide to go firewall to tail, but you only need about 40"x36 to do one front footwell.
WARNING this does NOT duplicate the stock color or texture, so be aware that a partial job will look like a partial job.
BONUS this made the car slightly quieter - I had to turn the stereo's SVC down a notch.
They also offer vinyl heel pads - you could order one of those and glue it in place over your wear holes, fixed for under $10!
Old May 5, 2011 | 06:30 PM
Tofuman's Avatar
I'm hoping for stockinteriors.com to carry Fit molded carpets someday. They have some quality stuff from what I've seen.
Old May 13, 2011 | 01:37 AM
BlueCell's Avatar
I'd buy some super mat Mouse pads from Frys, cut those and sew them in there, thats some nice cushion lol(or just use some plain rubber). I always wanted to tear out the carpet and spray some liner in there, but then all my wires would be exposed and i'd have to find something to cover that up.
ahhill
Nov 22, 2017 12:29 PM
john-fit
Oct 7, 2009 08:29 PM
incubus_of_habit
May 29, 2009 03:30 AM
jacksan1
Dec 16, 2008 05:29 PM
Jonniedee
May 18, 2006 09:49 PM
