1 More TPMS Question
Old May 6, 2011 | 02:10 PM
corps's Avatar
Hey FitFreak, sorry for yet another TPMS question, but i just changed rims recently, and as you know the TPMS light came on. I was wondering if it was possible to get the old TMPS in my stock rims and put them into my new rims. When i was changing the tires yesterday, i didnt see any TPMS or anything so im assuming the TPMS is inside the tire? is that correct? thanks for all your help
Old May 6, 2011 | 05:00 PM
Unforgiven's Avatar
Yup, the TPMS is inside the tire.
It should look something like this:
[/IMG]
Old May 6, 2011 | 05:02 PM
Unforgiven's Avatar
Old May 6, 2011 | 05:04 PM
Unforgiven's Avatar
[/IMG]
Unforgiven's Avatar
Old May 6, 2011 | 05:05 PM
Unforgiven's Avatar
Apparently I don't know how to post pics... here is a link...
ImageShack® - Online Photo and Video Hosting
Old May 6, 2011 | 05:15 PM
Brain Champagne's Avatar
attached to the rim, not the tire but yes, on the inside
Old May 6, 2011 | 05:16 PM
Hootie's Avatar
^^ The pic Unforgiven was trying to post.
The TPMS sensor is mounted on the wheel not the tire. Its easy to see if the sensor is installed because you'll see the sensor's cap surrounding the valve steam.
Old May 6, 2011 | 08:29 PM
corps's Avatar
i see thanks for helping me confirm my question. Does anyone know how the sensor tells the car there is low pressure though?
Old May 6, 2011 | 08:46 PM
Hootie's Avatar
If I recall correctly it takes note of the wheel's rotating speeds. The less pressure a tire has, the smaller its outer diameter will be and vice versa.
Generally speaking, the Fit's TPMS will indicate that there is a low tire once a tire's pressure goes below 28 PSI.
Old May 7, 2011 | 09:19 AM
Bthasht's Avatar
Unmount tires on both rims and switch them over. Or eliminate light by following my signature link.
Bogs2013
Jun 11, 2013 12:47 PM
corygibson
May 23, 2013 09:15 PM
mozarwasagenius
Sep 18, 2011 08:03 AM
stock0891
Nov 12, 2008 08:49 AM
BrianT
Sep 10, 2008 02:52 PM
