Bolts for test pipe????
Old Jun 4, 2011 | 11:19 PM
Demon Fit's Avatar
Bought a T1R test pipe from a member on here and was wondering if anyone knew what kind of bolts I'm going to need to install this beast? I've mis-placed the extra bolts that came with my cat-back exhaust. Any info is appreciated.
thanks,
~Demon
Old Jun 5, 2011 | 05:18 AM
Koi's Avatar
Koi
Can probably just use exhaust spring bolts. My b-pipe didn't come with anything to bolt onto my muffler so I went to the local Kragen/pepboys/autozone and bought 2. Or if you need ones that will fit into your header's threading you can probably just order a couple from a honda dealership.
Old Jun 5, 2011 | 05:55 AM
Demon Fit's Avatar
someone told me to use the spring bolts from the the stock cat... I'm not sure I know what a spring bolt is
Old Jun 5, 2011 | 05:57 AM
Demon Fit's Avatar
Btw... I'm using factory exhaust manifold if that makes any difference?
Old Jun 5, 2011 | 08:56 AM
gawa's Avatar
The stock spring bolts that hold the test pipe / cat to the headers looks like this:
You can reuse the ones holding your cat to the headers at the moment.
As for the test pipe / cat to midpipe connection, I had to buy 3 regular bolts and nuts for it, the bolt was about an inch long and iirc was an m8 or m10 size. The stock cat, iirc, has studs pressed/welded in but the test pipe doesn't.
Old Jun 5, 2011 | 11:26 AM
Bthasht's Avatar
Use the stock spring bolts at the exhaust manifold, and purchase new bolts for the other end due to the stock cat bolts being pressed on. M6 i believe available at Lowes. I will be posting a DIY soon when I get home
Old Jun 5, 2011 | 10:03 PM
Demon Fit's Avatar
Could you shoot a PM my way with a link to your DIY whenever you get it posted?
Old Jun 5, 2011 | 10:06 PM
Demon Fit's Avatar
Dis-regard last... I just now saw the link in your sig....
Bthasht
14
Apr 22, 2021 02:46 PM
Demon Fit
Jun 26, 2011 11:28 AM
sevenaprils
Mar 17, 2011 02:47 PM
Mr.Black
22
Aug 15, 2007 11:54 AM
Alex Rodriguez
Jul 19, 2005 05:31 PM
