Question about dashboard lights and icons while keys in position II...
Old Jun 6, 2011 | 08:03 PM
Santiad's Avatar
just noticed while listening to the radio with the keys in position II :
The usual three that light up on the left and stay on for a bit (engine, battery and oil) light up fine but after 20-30 seconds the engine light blinks 5 times then disappears.
Is this normal? I just paid out the behind (see my 2 previous threads) and had new coils, a maf sensor, and plugs put in and NEED to know if I should drive the car back in to have them fix something. I called but the advisor said it was normal. Never noticed it blinking before and usually blinking indicates a problem.
As always thanks for everyone help in advance.
Old Jun 6, 2011 | 08:17 PM
Steve244's Avatar
I believe that's normal. What's important is what the CEL does when the engine is running.
What's not normal is to listen to the radio in position II without the engine running. Accessory (position I) is intended for this and will save your battery.
Old Jun 6, 2011 | 08:20 PM
hyperfit's Avatar
Mine does that too, it's completely stock. Totally normal.
Old Jun 19, 2011 | 01:46 PM
Steve244's Avatar
Earlier response was incomplete. While rereading the owner's manual (yeah, high gayness factor here) I came across this:
Originally Posted by 2009 owner's manual page 304
Readiness Codes
Your vehicle has certain ‘‘ readiness
codes ’’ that are part of the on-board
diagnostics for the emissions
systems. In some states, part of the
emissions testing is to make sure
these codes are set. If they are not
set, the test cannot be completed.
If the battery in your vehicle has
been disconnected or gone dead,
these codes are erased. It can take
several days of driving under various
conditions to set the codes again.
To check if they are set, turn the
ignition switch to the ON (II)
position, without starting the engine.
The malfunction indicator lamp will
come on for 20 seconds. If it then
goes off, the readiness codes are set.
If it blinks five times, the readiness
codes are not set.
If possible, do not
take your vehicle for an emissions
test until the readiness codes are set.
Refer to Emissions Testing for
more information (see page 329).
so... the complete answer is; it's normal given they disconnected the battery while they were working on it. By now you shouldn't see the blinking. And you still shouldn't be listening to the radio in position II .
Cubsfan
Sep 4, 2018 11:15 AM
empell
Feb 2, 2015 09:34 PM
muffins
Aug 13, 2014 09:48 AM
paulfit
May 14, 2010 02:02 PM
hisame2332
Sep 21, 2005 07:30 PM
