how to remove hazard switch?
Old Jun 28, 2006 | 12:55 PM
sillypuddy's Avatar
Someone that Posts too much
I looked at the various diagrams and can't figure out how to take the panels off to install my JDM hazard switch.. anybody help?
-joe
Old Jul 3, 2006 | 11:55 AM
Mugen_Dom's Avatar
Here's how you do it with the JDM model.
The NA models are pretty much the same:
http://www.cyberstork.com/cgi-bin/ho...dure&imgtp=fit
After you get the guages off, you need to stick your hand behind the hazard switch/vents and push the switch out
NOTE: I take no responsibility for any damage to yourself or your car if something goes wrong!!!
Old Jul 3, 2006 | 06:34 PM
sillypuddy's Avatar
thanks..
-joe
Old Jul 23, 2006 | 06:48 PM
sillypuddy's Avatar
i just did it in my driveway.. holy crap it's not easy
and i drop one of the trim clips down the eternal area behind the dash.. and i heard it drop to some metal-sounding-place.. can't find it now..
i hope the clip dont' start rattling.. it would drive me nuts
-joe
Old Jul 23, 2006 | 08:17 PM
aziatiklover's Avatar
Master FitFreaker
nice infos man
Old Jul 29, 2006 | 04:04 PM
t-bone's Avatar
I used the shop manual that I found online to help me remove everything to install the JDM hazard switch.
Here are the pictures from the shop manual I used:
The clips are not too difficult to pull out. Just use constant force.
You need to remove the plugs that plug into the instrument cluster to remove the cluster.
Squeeze on the clips that hold the hazard switch in place. This will allow you to pull the switch out.
I just finished this. It took maybe about 20 minutes. Be sure to have a Phillips head screwdriver that is magnetic. Makes it much easier to remove and replace the screws.
Old Jul 29, 2006 | 06:36 PM
sillypuddy's Avatar
they have clips at the back of this piece, and one of them fell down.. i can never find it again
-joe
Old Jul 29, 2006 | 06:39 PM
nexus4400's Avatar
Whoa, is it even worth the hassle?
Old Jul 29, 2006 | 10:21 PM
t-bone's Avatar
It's not as difficult as all the pictures make it out to be. Each piece is removed pretty easily. The pictures really help with the whole process though.
I like the way it looks now though. The hazard button is more easily spotted now.
Old Jul 29, 2006 | 11:10 PM
sillypuddy's Avatar
if you had to ask, then no, it's not worth the hassle :-)
it's a jdm thing..
-joe
Old Apr 2, 2007 | 11:32 PM
bryan720's Avatar
i changed mine in 5mins haha i just broke the old cover face off the used a 2 flat head screwdriver on the tabe that holds the hazzard switch in place, then pry it out, un clip the plug, plug the new hazzard switch in and it poped right back in.
Old Aug 1, 2007 | 12:08 PM
smatts's Avatar
Honda Fit Forums Moderator
So does the gauge trim just pull off?
Old Aug 1, 2007 | 12:13 PM
t-bone's Avatar
yes, just pull slowly. it will come off with a little force. you'll see in the first drawing I posted that it is just held in by some clips.
Old Aug 1, 2007 | 03:04 PM
smatts's Avatar
Well I got it done today, took me about 35 min , I lost a clip and a screw down the back while taking apart the instrument panel. Luckily I found both by opening up the fuse panel and looking back there with a flashlight. I think in total I removed 11 screws. I love how the Hazard pops out in red
Old Aug 1, 2007 | 03:36 PM
Crixtala's Avatar
it's a jdm thing..
-joe
Seriously... I love JDM bling just as much as the next person, but what's the point...? Going through all that crap to install, taking the chance of loosing clips... just to have a red hazard button...
Old Aug 8, 2007 | 08:00 PM
scarygoldlion's Avatar
i changed mine through the ac vents.
Old Aug 9, 2007 | 02:36 AM
Canadian_R32's Avatar
was it difficult? how did you remove the a/c vents?
Old Aug 9, 2007 | 03:23 AM
jeimusu86's Avatar
that's awesome...u must have some finesse using those two flatheads
Old Aug 9, 2007 | 11:52 AM
i actually bought some stuff from sears. it onyl cost me $5 it helped a lot! here are some pics of the install.
Note: From the words of Mugen Dom "I also take no responsibility for any damage to yourself or your car if something goes wrong!!"
Old Aug 9, 2007 | 02:35 PM
looks good! .. no nicks or cracking of any plastic or anything? does the a/c vents just snap out when you pry at it?
oh one more thing, for those that did it through the dash, have you noticed any new rattles or anything of that sort?
