fan stopped working???
Old Jun 12, 2011 | 06:45 PM
pip_rocks's Avatar
So today I went to turn on the a/c and lo and behold my fan stopped working, but only on the 1st-3rd settings. Maximum worked fine. I was told this is a relay issue.
Has anyone else had this happen? I'm getting aggravated because this is the 2nd annoying thing to happen to my Fit and it just cracked 1500 miles today.
-di
Old Jun 12, 2011 | 07:06 PM
malraux's Avatar
It's not a relay issue, its a resistor array issue. It should be covered either by a warranty or goodwill, depending on the age of your car. With 1500 miles though, this shouldn't have happened.
There is a TSB for the 09 year cars for this same problem though. Check the thread here.
Old Jun 12, 2011 | 07:18 PM
pip_rocks's Avatar
Thank you so much! I searched and it brought up nothing, had no idea it was a prior issue.
Old Jun 18, 2011 | 07:35 PM
ian-white's Avatar
mine just went out i have had it for a yr and only 27k miles and i never use my fan and it went out i was like wtf but honda fixed it under warrenty
Old Jun 19, 2011 | 05:57 PM
pip_rocks's Avatar
Yeah I took it last week and got it fixed. What year is yours? Cause I wonder if this will be an issue again for the '11s.
Old Jun 20, 2011 | 12:52 PM
ian-white's Avatar
mine is a 10
Old Jun 20, 2011 | 01:15 PM
SSMTEN's Avatar
I had this happen a couple weeks ago. It seems like there have been a handful of members experiencing this problem lately
Old Jun 20, 2011 | 01:21 PM
ian-white's Avatar
i asked honda if they had heard of anything from higher up and of course they hadn't. but i never use my fan so idk how it would go out after a yr
Old Jun 20, 2011 | 02:00 PM
spin out's Avatar
since it's a known issue with its own service bulletin i wonder what the chances are they'd fix it for free even after warranty??
i had the same thing happen to my old camry (certain fan settings not working). and not too many things failed on that car.
Old Jun 20, 2011 | 02:12 PM
M.R.fit's Avatar
They wouldn't fix it for free for me, but its not that much of a PIA to do yourself.
They did recommend that I replace the motor assembly as well, but I didn't feel like dropping $100+.
Replaced the resistor array for $20ish and a half hour of my time a month ago and its working fine.
Faoladh
Aug 17, 2017 10:06 AM
seanpatrickk
Aug 10, 2015 07:32 PM
Marrk
Sep 29, 2013 02:19 PM
xwikedonex
Aug 7, 2013 09:24 PM
Trogdor!
Sep 17, 2010 04:33 PM
