Front top mount protruding out??
Old Jun 16, 2011 | 03:00 AM
patyong's Avatar
hey guys, I need a quick advice. Any one of you experience this before?
This happened when I was putting back my stock suspension. I remembered reading this somewhere in the thread but I can't seem to find it anywhere. Please help
Old Jun 16, 2011 | 03:20 AM
feared's Avatar
did you put back all the rubber mounts?
Old Jun 16, 2011 | 03:30 AM
patyong's Avatar
yep... all rubber mounts are in.
Old Jun 16, 2011 | 07:36 AM
patyong's Avatar
Anyone has servicing manual for honda original shock assembly??
Old Jun 16, 2011 | 03:23 PM
Goobers's Avatar
you put it back in the wrong order.
Old Jun 16, 2011 | 05:42 PM
danger69's Avatar
Did you compress the suspension when you put it back together? The nut #8 should be taught which compresses the springs which takes up any slack once the car is lowered.
Old Jun 16, 2011 | 08:39 PM
patyong's Avatar
Yeah I did, well at least i think I did but I suspect the nut didn't go as much in as it should have. I'll give it a go later on. Thanks Goobers for the chart.
Old Jun 17, 2011 | 12:33 AM
Goobers's Avatar
Actually, nut isn't that important for the spring... as when you lower your car onto the ground, the car pushes on grommet #13, which sits directly onto of bearing #11. And bearing #11 pushes on top perch #9. When the car is on the ground, there will most likely be a gap between nut #8 and bearing #11... any contact is minimal.
What you actually want is to minimize the distance between nut #8 and #17... the tighter you squeeze those two together, the less the top of the strut moves relative to the car.
edit#1
patyong:
Looking at your picture some more, I think you put the nut on top of the grommet #13, instead of the grommet on top of the nut.
In the chart, you'll notice the box surrounding most of the parts... that's to indicate a "complete strut assembly"...
edit #2
Oooh, you're in Australia... so you have a JDM Fit then. That picture is from Bernardi Honda for USDM. I don't know if that matters, since I don't know if there's a different in the strut assembly.
Old Jun 18, 2011 | 11:38 PM
patyong's Avatar
Hey Goobers, thanks for you input. You're absolutely right. How silly of me to place that nut on top of the grommet. I've got everything going and thanks again!
ite
26
Dec 26, 2022 06:05 PM
ChuckDustin
Apr 12, 2019 12:47 PM
jackanyon
Mar 15, 2017 11:07 AM
allmotormark
Oct 10, 2014 01:16 PM
YeeFit
Aug 29, 2008 01:26 AM
