A/C switch giving me some problem
Old Jul 6, 2011 | 09:59 PM
StormSurfer's Avatar
Hi to all my friends here in FF....Tomorrow i will take my Honda Fit Sport 2010 to warranty because i having problem with the A/C switch of my Fit.The switch that is giving me problem is show in the picture with a red circle.
What the switch is doing is if you give a little tap or a light touch (I am not pushing the switch to turn off the A/C) over the switch it turns off the green light and the compressor turns off too.If you try to turn on the A/C you must press this switch a lot of times to turn on the A/C.This switch turn off the A/C alone too.The switch is not making the click sound like the defrost switch does.I think that this switch is bad and it must be replace.This is the first time that my Fit is going to warranty.Did anyone had problem with this switch?Any ideas what can it be?
Old Jul 6, 2011 | 10:22 PM
Starks's Avatar
I haven't had a problem with this switch. I rarely turn the A/C on.
However, I did notice today that after about an hour and a half of driving with the A/C on, this switch felt really hot to the touch. Can this switch be popped off in any way? I'd like to access the bulb behind it. The temperature of the switch was alarming.
Good luck. I'm sure it's an easy fix. Just make sure they don't scratch up your dash when trying to pry off the panels.
Old Jul 7, 2011 | 02:29 PM
The switch is bad.Today i take my Fit to Honda and they found that the switch is bad.This problem is with ALL Honda Fit 2009-2011.This problem is real.What is causing the switch heating up and also to break..... And they still using the same part number.This switch will give me problem again for sure.This link is from a friend here in FF with the same problem.
https://www.fitfreak.net/forums/2nd-...-c-switch.html
Old Jul 8, 2011 | 12:41 AM
Ric01's Avatar
I have not had any bad experience with my AC switch yet but my FIT will be one year old this Aug. Would I be screwed if the A/C switched broke after my 1 year
....Is this A/C switch under 1 year warranty or 3 years?
Old Jul 17, 2011 | 03:12 PM
SheepNutz's Avatar
I had mine replaced for this exact problem a few months ago, and the new one's been working just fine.
Old Jul 17, 2011 | 07:27 PM
damn, yet another problem to look out for.
thanks for the headsup!
Old Jul 21, 2011 | 11:39 PM
Ric01's Avatar
I have been keeping an eye on the A/C switch the last two weeks when switching on my A/C for two hours straight...seems to have no problem so far... knock wood
Old Jul 25, 2011 | 01:29 PM
Just a few hours ago my Honda Fit went to the Honda dealer to replace the bad A/C switch.Now the switch is making the "click" sound.The one they remove did not make the sound and don't want to stay "ON".I hope that the new one be better.Guys....just check your A/C switch to make sure is working fine.
Old Jul 25, 2011 | 02:05 PM
Texas Coyote's Avatar
My car is 5 years old and no problems with the A/C switch..
timmcd
Jan 6, 2015 12:46 PM
phenoyz
Aug 8, 2013 05:29 AM
Lyon[Nightroad]
May 2, 2010 02:12 PM
OhNineFIT
Sep 3, 2009 12:19 AM
Mugen_Dom
Aug 7, 2007 01:26 PM
