Sound system help!
Old Jul 18, 2011 | 01:25 AM
kam's Avatar
kam
Question Sound system help!
Ok, I'm interested in getting a sound system for around 800-900 including install. I need details on what sounds best in a fit, and what all I need to get! I don't want it to be so powerful that it sounds bad when it's cranked up. Give me your opinion on what I need! Thanks!
Old Jul 18, 2011 | 03:09 AM
Jamy's Avatar
"sounds best" is strictly a matter of individual opinion. As everyone likes their own qualities when it comes to music. Me for instance. I have to have bass. I can't stand flat music at all. It has to have a little bump.
You need a head unit for starts. The stock HU has a built in equalizer that really messes with the way stuff sounds. Depending on how much you're going to push it you may need speakers. I went with a subwoofer since the speakers were plenty loud enough. Sub in a small car means you don't need huge to be loud. My 12" makes my house shake when I pull into the driveway if I have it turned up to 30. 40 will make pictures fall off the walls. I'll probably move to a 8" or 10" shortly to get some space and weight back.
Check out the I.C.E threads. There are plenty of examples of things people have done.
Good luck
Old Jul 31, 2011 | 02:54 AM
its_bacon12's Avatar
How in depth in the install do you want to go? I just joined because I am going to post a build log on my sound system install when I get started.
Mine will be pretty intensive because of how long I have been in audio and my preference of high quality sound reproduction. My home theater audio setup was about $4k itself, so I have pretty high expectations. My audio system in my car will consist of a 3 way active front with a 12" subwoofer in a glassed box in the hatch.
I can help you pick out some gear if you want. There are a LOT of very high quality internet brands I bet most people have never heard of that are much more wallet friendly than many mainstream brands.
Old Aug 2, 2011 | 08:11 PM
Jensen Healy's Avatar
I don't think it's worth it since Honda leaves you hardly any space to stick amps or speakers. It's so tight I can't even stick my amps next to the spare tire, as I did in my 1994 Sentra SE-R
Old Aug 2, 2011 | 08:59 PM
solbrothers's Avatar
Replace your headunit with a good one and you will be so happy you won't worry about subs/speakers. that's where im at. the OEM headunit is garbage
Old Aug 3, 2011 | 12:31 AM
Vince_TB's Avatar
I feel that on stripped down music(Dub, acoustic etc..) the OEM sounds good but with music with lots of guitar distortion it sounds bad!
Old Aug 3, 2011 | 12:37 AM
do you have a good aftermarket headunit? it's night and day difference between that and the low quality stock headunit
phil_qc
Feb 26, 2019 01:39 PM
Zero2Hero
Feb 26, 2019 01:34 PM
PHOENIX
Sep 12, 2008 01:42 AM
phoenity
Mar 17, 2007 03:16 PM
cheffyjay
Jun 26, 2006 06:58 PM
