Stock Sport Rims???
Old Aug 1, 2011 | 03:26 PM
ccl088's Avatar
Stock Sport Rims???
Anyone know the specs of this rim? I need the width and offset.
I know they are 16" but don't know the rest. Thanks
Old Aug 1, 2011 | 03:32 PM
Vanct's Avatar
16x6", ET+53, ~18.5 lbs.
I wish more people would use forum search, though.
Old Aug 1, 2011 | 03:37 PM
ccl088's Avatar
I assume ET means offset at +53mm? I ask because I am looking at some rims 16x7 with +40mm offset and plan to use 205/50/16 tires. Will this setup work?
Old Aug 1, 2011 | 03:43 PM
Vanct's Avatar
Yeah, it's +53mm. Depending on how low you go, that may not work because it will probably rub.
Old Aug 1, 2011 | 06:15 PM
ccl088's Avatar
Not changing height, what do you think will rub the front wheels when turning?
Old Aug 1, 2011 | 08:08 PM
Vanct's Avatar
+45 or higher is safe, but some people start rubbing tires any lower, depending on the setup. Since you're not lowering, then you won't have to worry.
Old Aug 1, 2011 | 09:41 PM
ccl088's Avatar
This is 40mm offset so we will see...
p nut
Sep 11, 2014 04:15 PM
i dnt f!t
Mar 3, 2009 04:29 PM
sirfit08
Sep 5, 2008 07:32 PM
Beretta
Apr 13, 2008 05:03 PM
Frenchi169
Mar 31, 2008 10:49 PM
