Opinions on ClutchMasters Stage III for Hi Boost GD3?
Old Aug 10, 2011 | 03:42 PM
lcq4blackstar's Avatar
Question Opinions on ClutchMasters Stage III for Hi Boost GD3?
So its time for a clutch and I've been searching threads... was looking at the SPEC stage III+ and a JUN Auto Ultra light flywheel. After some google searches I came across the ClutchMasters kit. It comes with aluminum flywheel as well as a comparable clutch to the SPEC unit. Other Honda's are happy with it from what I read. Does anyone have this? Or have anything to say about this kit good or bad?
I'm also going to do the OBX LSD at the same time unless someone has any negative info to share about it...
So please good or bad, lets hear what you are running or any suggestions on these products!
Clutch Masters- Your High Performance Specialists
-thanks
Old Aug 10, 2011 | 04:32 PM
Texas Coyote's Avatar
I'm tuned in to see what opinions are expressed.
Old Aug 10, 2011 | 07:17 PM
So I've spent the better part of the morning doing some google reading on the OBX LSD's, looks like there hit or miss on quality... unfortunately there isn't much options that I know of for the GD3. My previous car had a qualfe unit and it worked well. I do remember a member here that raved about the unit but was NA... I hope people can reassure us on the OBX unit for our application.
Old Aug 10, 2011 | 07:26 PM
JDMchris.com's Avatar
I run THIS
As far as LSD, why not M Factory. I have been abusing the crap out of mine and its still holding up well. The OBX from what i have seen WILL fail unless most of the hardware is replaced and torqued to spec... and even then i have seen them fail.
Old Aug 10, 2011 | 08:32 PM
kylerwho's Avatar
spoon fed
spoon and j's racing also have a lsd for the gd3.
Old Aug 10, 2011 | 09:29 PM
Not looking for a clutch type...
Old Aug 10, 2011 | 09:31 PM
I was under the impression they stopped making them... I'll have to give them a look again. cheapest I could find the qualfe for was $950.00, a little expensive for the wife's car...
Old Aug 10, 2011 | 09:42 PM
kylerwho's Avatar
spoon fed
666fit666
Jul 27, 2017 12:14 PM
AJR Jay
13
Nov 29, 2012 03:44 PM
laurent_teo
Sep 16, 2009 03:06 AM
QuickGD3
Sep 10, 2008 05:25 PM
sLiVeRwOrM
15
Aug 8, 2007 10:44 PM
