Other Options For Horn Replacement?
Old Sep 28, 2011 | 06:09 PM
PHAMBAM's Avatar
I know the 09 Accord is the popular one but I was just wondering if the newer Accords horns are plug and play also? What other horns are plug and play for the Fit? And where can I purchase them? Thank you
Old Sep 28, 2011 | 06:20 PM
FitCrazy80's Avatar
Phambam,
Just to let you know, the '08-'11 Accord horn is identical (p/n 38150-TA0-A01). I heard that this horn is supposed to be higher pitched and more assertive sounding then the horn that the Fit comes standard with. This horn is $12 over at hondapartsnow.com. I plan on swapping this bad boy into my '07 in the near future
As for any other Honda horns that work in the Fit, I'll have to do some research on the matter because I'm still a novice when it comes to horn swaps. I'm sure that another Fit Freak will be more than happy to add their .02 cents to this thread
Old Sep 29, 2011 | 04:18 AM
PHAMBAM's Avatar
Thanks FitCrazy! Yeah majority made the switch to the accord horn. I need something that can replace this Road Runner sounding horn. mee meep
Old Sep 29, 2011 | 06:27 AM
TrungLam's Avatar
I have PIAA SportHorns installed, no relay needed...
Old Sep 29, 2011 | 11:01 AM
D50boy's Avatar
Hella Twin Supertone Horns. Popular with the Subaru crowd, not plug and play, but who cares.
Old Sep 29, 2011 | 11:24 AM
Krimson_Cardnal's Avatar
All the horn you'll ever need, a true Italian Air Horn: https://www.fitfreak.net/forums/gene...s-install.html
You can listen to one here: STEBEL S.p.A. - horns
I've done the install, quite easy. This poster found a wiring kit that simplifies it.
Old Sep 29, 2011 | 01:21 PM
FitStir's Avatar
You could also get a Bosch Euro Twin Horn Part # 08P80-TF0-000, it's a JDM Honda accessory, and should be relatively plug and play (I think all you have to run is a relay), the rest of the connections should be a direct plug in to our OEM connections.
Originally Posted by JDM_DOHC_SiR
....JDM OEM Honda GE6/8 Dual Bosch Euro Horn kit P/N 08P08-TF0-000
Old Sep 29, 2011 | 11:47 PM
PHAMBAM's Avatar
Can you describe the sound of the horn? Maybe a video clip or a comparison. Good lookin out!
Old Sep 30, 2011 | 12:02 AM
PHAMBAM's Avatar
I like the sound of this horn but its running 40-50 bucks? Where can I get them for a cheaper price by any chance?
Old Sep 30, 2011 | 12:18 AM
TrungLam's Avatar
Not cheap but well worth it, no more embarassing meep-meep.
Amazon.com: PIAA 85110 115db 400HZ + 500HZ Sports Horn: Automotive
Old Sep 30, 2011 | 02:25 AM
Don't forget to consider this: https://www.fitfreak.net/forums/gene...s-install.html
You can hear it here: STEBEL S.p.A. - horns
And buy it here: Amazon.com: Horn, Stebel Compact Nautilus Twin Air: Automotive
I would pick up the wiring kit as well.
I, and others, have installed this horn - first class all the way!!!
K_C_
Old Sep 30, 2011 | 04:23 AM
Texas Coyote's Avatar
K_C_
I put it on my Amazon wish list
Old Sep 30, 2011 | 08:56 AM
FitStir's Avatar
I haven't bought it yet, though I'm really close to purchasing it (still debating). It costs about $90 not including the price of shipping from Japan.
I've heard people say it's like the older German cars, I guess it makes sense cause Bosch makes it for Honda, but I couldn't find any soundclip on the net. I'll let you know if I find anything or install it.
The Stebel as mentioned is the other one I'm considering, definitely a loud horn.
Old Sep 30, 2011 | 04:59 PM
The Stebel will mount to the OEM point w/ a bracket. Drilled thin bar stock or corner angle off the shelf. It also has a port to run the s=air intake inside the engine compartment. I ran it in across the inside top of the hood latch brace across front of compartment- hi&dry out of the weather. It is a good detail. You need a relay and pull power off the battery w/ a fused lead. OEM trips relay - battery toots it.
Anything else is child's play... ;-)
DeltaBond
Aug 26, 2013 04:46 PM
SevereService
Feb 2, 2012 08:23 AM
FLEALAMI
Jan 23, 2010 03:57 PM
CMegalodon
Mar 12, 2009 02:04 AM
ckdk1
Mar 1, 2009 08:00 PM
