Help Installing UBT101 Bluetooth Module
Old Nov 11, 2011 | 01:56 PM
byungkuk's Avatar
I've been mulling getting bluetooth for my GD3.. I ended up buying the UBT101 bluetooth module from craigslist (super cheap!) I've never done this type of modification before. I would like someone to just guide in the right direction....
I've found several instructions on removing the stock HU.
Do I need to buy a harness?
Has anyone installed bluetooth modules from this company before? Any guides out there?
Thanks.
Old Nov 11, 2011 | 06:14 PM
lashlee's Avatar
I've installed a few bluetooth kits and removing the H/U may or not be necessary. I've never installed one of models that you are but I have installed a few of the motorola ones that can tie into the OEM speaker wires and using a male and female radio harness could make this easy.
If you can install a basic head and four you should do just fine.
Old Dec 13, 2011 | 04:16 PM
byungkuk's Avatar
hmmm.. it's this one.. I should get a harness right? for plug and play
Old Dec 17, 2011 | 09:02 PM
lashlee's Avatar
If you've got an OEM radio I would get a male and female radio harness and just tie the BT module into that wiring. That way if you ever get rid of the car you can return the wiring back to OEM. Besides this will let you have the correct colors instead of relying on translating the OEM colors.
Old Dec 21, 2011 | 12:05 AM
byungkuk's Avatar
Would I be able to use a quick connect harness?
http://www.aftermarketcellular.com/ic/QCHON-2.html
Old Dec 21, 2011 | 08:07 AM
lashlee's Avatar
Yep! That should work
Old Dec 25, 2011 | 12:37 PM
byungkuk's Avatar
well it came but the plug doesn't fit into the control pod.. I'm thinking about just splicing the harness and connecting it to the control pod wires in order to maintain "plug-n-play"..
Old Dec 26, 2011 | 07:37 PM
lashlee's Avatar
That is what I would do. That way its removable in the future.
Action Jackson
Apr 6, 2024 02:38 AM
LLLC1393
Aug 2, 2017 05:37 PM
Mr_wick
Sep 11, 2016 08:01 PM
exl500
Jul 21, 2015 12:35 PM
Dirty_Sanchez
Aug 14, 2009 04:08 AM
