Wiring help needed -which gromet on firewall to use
I want to run a hot wire from ACC fuse to front of car for some LEDs. Any easy way to do this? I was looking at using the grommet for the hood release cable but to get to it need to remove fender inner liner - a lot of work.
Is there a constant hot wire under hood I could use?
I am adding a strip of LEDs along bottom of headlights and would like these LEDs on all the time.
Thanks
bill
Thanks
bill
Thanks I will have a look. Maybe remove glove box to access inside?
I dont think you ahve to remove the glovebox but I cant remeber for sure. If your reaching up behind the glovebox it should be up and to the left.
alexpan
Feb 10, 2013 06:08 AM
