for those with 205 50 16's
Old Dec 19, 2011 | 08:19 PM
Santiad's Avatar
I have them also (falken ziex 912'4)
Just curious to know what pressure you all keep yours at?
I do 39 but this winter my ride seems harsher than usual.
Old Dec 19, 2011 | 09:39 PM
MikeNSX's Avatar
37 front, 35 rear.
Old Dec 19, 2011 | 10:34 PM
climhazzard's Avatar
Originally Posted by MikeNSX
37 front, 35 rear.
34ish all the way around. I say "ish" because the temperature fluctuates so much lately in VA, it's hard to keep track. (It's said for every 10 degrees fahrenheit you increase/decrease 1PSI, which I've found to be very true).
Old Dec 19, 2011 | 11:39 PM
Codger01's Avatar
35 all the way around. The recommended 33 feels too squishy.
Old Dec 20, 2011 | 12:11 AM
Texas Coyote's Avatar
That sounds reasonable... I have found that when it gets cold the oil in the dampers thickens and rubber is less pliable so I have to drop the tire pressure instead of adding more air... I had been putting 35 PSI front, 31PSI rear with my old 195-55-15"s but the 205-50-16" Goodyear Eagle Authority tires... They are the same tire as Eagle GTs but with a slightly different tread sold only at Wal-Mart.. They are heavier and have much thicker sidewalls than other tires I have had on my 07 Fit... I have dropped the front to 29.5 PSI , rear to 28 PSI but the ride is still rough even when the ambient temperature is as warm as 50, 55 degrees F... I have my rear seats removed so I have to use less air in the rear tires than the front...
Old Dec 20, 2011 | 09:34 AM
RevToTheRedline's Avatar
I keep them around 36 or try to at least, seems to ride good.
cgs2000
Oct 3, 2017 08:47 PM
SlamminRC
30
Aug 29, 2014 09:47 PM
battouter
May 28, 2014 10:53 AM
schutzenfester
Oct 13, 2013 06:55 PM
runbikerun
Mar 31, 2010 06:42 PM
