Offset please help asap
Old Jan 26, 2012 | 08:23 PM
GE8Anderson's Avatar
ok ive tried serching, no answers. What im looking for is to see if on my 2012 GE8 will 17x7.5 with +40 offset with work with 205/40/17 on my fit and the kicker is im also wanting to lower it on lowering springs
Old Jan 26, 2012 | 08:47 PM
Wanderer.'s Avatar
Read this thread:
https://www.fitfreak.net/forums/2nd-...ng-thread.html
09 and 12 should be the same.
Old Mar 13, 2012 | 05:16 PM
Ray731's Avatar
I had that exact size on my fit and if you go thru my progress thread https://www.fitfreak.net/forums/2nd-...-progress.html you can see that size before the drop and after I put Drop Zone springs on it. The I went to a BIGGER size tire because of several issues including wheelwell gap. I went to Zeix ZE-512 215/45/17 tires on 17x7.5 +42 wheels and it worked great no RUB. Then I put on coil overs and RUB RUB RUB... With my coilovers all the way down on the 205/40/17's I had no rub except hi speed hard bumps on the freeway. (rare) I hope this helps along with all the info on here like...
https://www.fitfreak.net/forums/2nd-...re-thread.html
-Ray
Sorry bout bringing up an old thread...
Last edited by Ray731; Mar 13, 2012 at 05:17 PM. Reason: realized age of thread... dang...
Old Mar 13, 2012 | 08:38 PM
k20a298ek's Avatar
+45 min offset or you will rub.
Old Mar 14, 2012 | 12:16 AM
slp950's Avatar
Not true my friend. Check out my progress thread over in the GE8 photo/vid section, and look at some of my wheel/tire/spacer/suspension combos. With 17x7.5 et42f and et42+8 (final et 34)r and 205/40-17 on buddy club n+, only ever got very very slight rub on HUGE bumps/dips at highway speed. Unless I had 4 people in the car, then I would get some rub in the back. But not enough to worry about.
I also ran 17x8 et38f and 17x8et35r with205/40-17 falken 512 on dropzone lowering springs, and NEVER got any rubbing.
Currently, I'm running 17x7.5 et35f and 17x8.5 et48+8 (final et40) r with 205/40-17 falken 512 on buddy club n+ and ZERO RUBBING whatsoever.
Old Mar 14, 2012 | 12:36 AM
k20a298ek's Avatar
rota boost 17x7.5 205 40 17 rub on front liners. just play it safe and stay with 45 and up offset. no finger gap on my car lowered on d2 coilovers. if you were on regular springs you would rub big time
Old Mar 14, 2012 | 01:24 PM
slp950's Avatar
What is your offset on your rotas? I agree with you on playing it safe to stay with a +45 offset.
Old Mar 14, 2012 | 08:37 PM
k20a298ek's Avatar
17x7.5 +45 0ffset
SHOELAC3D
Aug 27, 2014 02:57 PM
Stay_Fitted
Jul 22, 2013 09:45 AM
kam
May 17, 2013 12:32 AM
sabawballs
Aug 17, 2012 04:11 AM
tokenasianguy69
13
Sep 2, 2010 01:11 PM
