Less power steering at high speeds?
Old Feb 2, 2012 | 02:30 PM
qwerqwert's Avatar
Is there any way to stiffen up steering at high speeds? I bought the 2012 Fit S M/T moving from a '98 VW Jetta, and maybe I just need to get used to it, but it feel like the power steering is a bit over-sensitive at highway speeds (70mph). Small movements of the steering wheel result in larger directional changes than I would like, making it more difficult to rest a hand down at 6 o-clock and just cruise.
" The fit has power-assisted rack-and-pinion steering with a revised rack to reduce steering effort a low speed. As speed rises, the power-assist gradually increases steering effort to a more reassuring level. "
Is it possible to change the fluid in the power steering system to achieve "more reassurance"?
Old Feb 2, 2012 | 03:27 PM
doctordoom's Avatar
Supervillain
It's electric power steering, no fluids. I'm thinking it could be a lot of work to change its characteristics.
Old Feb 2, 2012 | 03:53 PM
Black3sr's Avatar
At high speed would be more prudent to use 10 and 2. Steering is fine then.
Old Feb 2, 2012 | 05:39 PM
JCrimson's Avatar
pull the fuse.
I DD with zero power steering. no big deal. love it!
Old Feb 2, 2012 | 06:04 PM
Krimson_Cardnal's Avatar
This has always been my preferred steering position, but on the Fit it just doesn't work very well until you get accustom to it's handling characteristics.
Black3sr hit it - thumbs above the spokes. It is a well designed steering wheel.
K_C_
Old Feb 2, 2012 | 07:54 PM
FitStir's Avatar
Thumbs up
Originally Posted by JCrimson
pull the fuse.
I might just try that...
EMC2
Mar 25, 2017 04:45 PM
owner2009fit
Sep 28, 2008 07:25 PM
LizardKing
Jan 29, 2008 03:55 PM
gar1013
Jan 5, 2008 07:39 PM
bobbied
Jul 9, 2007 04:19 PM
