adding hitch/trailer, need to beef up suspension
Old Feb 15, 2012 | 07:43 PM
fitigued's Avatar
i haul a lot of heavy building materials in my 07 fit and my back end tends to sag. decided to add a hitch and just use a trailer from now on. i bought these springs but aren't sure they'll even fit. it says they're 14" long. does anybody know what the height of an uncompressed stock rear spring is? also, should i be replacing the rear shocks as well? saw the DIY post about monroe rear air shocks. seems like everybody suggests staying away from air shocks. has anyone replaced the rear suspension for the sake of towing (and not performance handling)? what springs/shocks did you use? thanks in advance.
Old Feb 17, 2012 | 09:57 PM
breadtrk's Avatar
Get a truck dude. This car ain't safe on the road with 200lbs of chicken feed in the back much less a trailer and load. Nothing back there but reshaped beer cans to attach a hitch too. You crazy.
Old Feb 18, 2012 | 12:36 AM
Krimson_Cardnal's Avatar
I've got a Curt hitch on my 2010 and haul a 4x6 home made utility trailer.
I've hauled 450# of shelving units w/ no issue.
Trick is to minimize the tongue weight.
I kept mine under 50lbs and saw no issue on stock set-up.
You can search 'trailer' and find stuff.
Here's one thread: https://www.fitfreak.net/forums/eco-...-2010-fit.html
All cautions of hauling w/ a small class car apply.
K_C_
Old Feb 18, 2012 | 01:40 AM
solbrothers's Avatar
OP you don't need to beef up the suspension. do like ^ says and load the trailer correctly
Old Feb 21, 2012 | 10:55 PM
fitigued's Avatar
i have to testify that the monroe air shocks have made a HUGE difference in handling. that has to be the best $47.53 i ever spent (amazon.com). kudos to manxman for his DIY instructions.
car handles like a dream. good god. with no load in the trunk and pumped up to 20psi, the jumper cables and other junk i have in the spare tire well bang around a little bit going over bumps, so i might try 15psi for normal driving.
after 15-minute test drive with plenty of lateral acceleration, height of the rear tire wells are at 25". they were at 24.5" before the mod. i initially pumped it up to about 50psi and it was jacked up to about 26", perfect for my new hitch/ball/trailer getup. the ball mount was a little shy of the 7" rise needed, so the ability to pump it up to level the trailer will be nice. will report back once my mount and ball arrive.
Old Feb 22, 2012 | 08:23 AM
fitigued Welcome to the freakworld!
This sounds interesting. GOOD find on the DIY, Post back w/ pics, what hitch you going for?
Ky1eRC
Oct 27, 2020 08:46 AM
max503
Jul 14, 2017 04:52 PM
SilverEX15
Feb 4, 2015 11:51 PM
shawnshank
Jun 14, 2011 06:30 PM
CuTeBoi
Jan 7, 2011 04:11 PM
