Speedometer/Tachometer/MPG's Not Working
Old Mar 11, 2012 | 11:16 PM
lilizm319's Avatar
Exclamation Speedometer/Tachometer/MPG's Not Working
I installed a sub in my trunk today, and I ran the positive lead through the car under the carpeting and out through the driver side firewall. While i was doing this, I must have knocked the wire loose that controls the speedometer/tach/mpg's because none of them now work. The EPS light came on along with the check engine light, engine temp light, and pass. airbag light. None of these were on before I ran the wire. I already checked the fuse and its not blown, does anyone know which wires go to the cluster? I have pretty much checked all of the wires I can see but it would make things easier if I knew which one to focus on.
Old Mar 12, 2012 | 08:32 AM
Ryanspoon's Avatar
Don't know if this will help but I had a similar problem on my civic, check the fuse for your instrument gauges and lights 1 fuse took out my whole dash while i was driving. Wires are usually pretty secure, you prolly bumped something and blew a fuse or your ground wire is grounded to close or in the same spot as your dash harsness' ground. Hope this helps
Old Apr 11, 2015 | 07:08 PM
leonine's Avatar
This happened to me last weekend. Not running any wires just reconnected the battery cable. Exact same symptoms. Did you figure out what the problem was?????
FELIXY69
Oct 7, 2022 12:48 PM
noripwr
Oct 21, 2014 06:48 PM
Foots
May 19, 2012 05:29 PM
stock0891
Feb 20, 2010 04:06 AM
dexue
Jun 3, 2005 01:06 AM
