i dont know if im a f**king moron or what...
Old Jul 20, 2006 | 10:35 PM
einhan's Avatar
but i cant put the damn seats in refresh mode... :'(
Old Jul 20, 2006 | 10:38 PM
gimme's Avatar
Master FitFreaker
refresh mode? is that where the front lay down with the rears?
Old Jul 20, 2006 | 10:41 PM
daviddahlb's Avatar
The trick is to recline your backseats.
They back up about only an inch maximum, but that is what you need to make it fit perfectly.
Make sure the front seats are all the way forward too...
Old Jul 20, 2006 | 10:45 PM
Kalash's Avatar
You can recline the backseats???
I usually get this done by pushing the fron seat foward - it's TIGHT, but it works...
But... by all the way forward I mean ALL the way - if it locks onto position, it's too far back to recline flat.
Old Jul 20, 2006 | 10:48 PM
daviddahlb's Avatar
It is not a true 'recline.'
It only goes backward about 1 inch to clear the way for the front seat's recline.
Old Jul 20, 2006 | 11:01 PM
einhan's Avatar
how/where do i push em back?
Old Jul 20, 2006 | 11:04 PM
Illusive's Avatar
OK here is an easy step by step way to do it:
1. Move front seats all the way forward
2. Pull the lever on the back seat and instead of lifting the bottom of the seat, push the seat back and you will find it will recline about 1 inch.
3. Recline the front seats until you are in refresh mode.
NOTE: If you find that they do not fit, try pulling the lever on the back seats again and lift up the bottom of the seats a little bit and recline the front seats and put them both down at the same time. That will ensure a snug fit.
Old Jul 20, 2006 | 11:59 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
4. MAKE SURE YOU HAVE THE HEADREST OFF!!
Old Jul 21, 2006 | 12:32 AM
Quantumcat's Avatar
The other key I found is dont forget to remove the headrest from the front seat.
Old Jul 21, 2006 | 12:35 AM
dacalac's Avatar
They are all correct. When you recline the backseat you will notice that the bottom portion of the seat will retract slightly to give that extra bit of space you need to put the seat down all the way.
Old Jul 21, 2006 | 12:36 AM
Kalash's Avatar
Heh...
I can't believe no one said that before
Oops.
Old Jul 21, 2006 | 08:09 PM
einhan's Avatar
Originally Posted by Kalash
Heh...
Oops.
i cant believe that needed to be said...
Old Jul 23, 2006 | 09:58 AM
gettinafit's Avatar
I had my Fit for 2 months and then another friend of mine who bought a BOM fit sport showed me that the rear seats recline a couple of inches! Much more comfortable!
Old Aug 2, 2006 | 10:47 AM
Votwim's Avatar
Great information
AFirefly
Feb 15, 2015 08:06 AM
walterbyrd
Dec 14, 2013 09:01 PM
mkbgdns
Feb 18, 2013 01:39 PM
Shockwave199
Sep 8, 2009 04:40 PM
2319
Jan 15, 2008 11:34 PM
