Strange noise after installing coilovers [NEED HELP]
Old Apr 26, 2012 | 07:56 PM
KaylaAnn's Avatar
So I'm kind of freaking out because I just installed a set of form and function coilovers on my 07 honda fit sport and I keep hearing what sounds like a tire skidding when I turn or accelerate. It doesn't happen all the time though, also the inside of my tires are bald. I'm thinking I might need an alignment but I'm not sure, since this is my first time dealing with coilovers.
Old Apr 26, 2012 | 08:02 PM
DreaMv's Avatar
sounds like rubbing lol.. what size tires/wheels do you have and how low did you go?
you probably need a fender roll/pull that should fix it
Old Apr 26, 2012 | 08:12 PM
KaylaAnn's Avatar
195/55 I have two or three inches of thread left on my coils before I can got as low as they can in the front
Old Apr 26, 2012 | 08:21 PM
punx45's Avatar
how were the insides of the tires before you installed the coilovers? how long have they been on?
inner wear is usually due to excessive toe, I believe. I would get an alignment done.
Old Apr 26, 2012 | 08:54 PM
KaylaAnn's Avatar
They had a decent amount of tread on them, I've had them on since January of this year.
Old Apr 26, 2012 | 08:58 PM
punx45's Avatar
yup so even if its not the source of the noise, time for an alignment!
if it is a tire type squeal similar to that of hard cornering, burnouts and short stops, then thats likely the source of the noise too.
if it were rubbing it would be more of a scratchy noise, and you would hear it very well in the cabin (kind of like how you do hitting a big puddle, or kicking up gravel). plus the outsides of your tires would be getting scuffed up as well, either the outer corners or the sidewalls.
Old Apr 26, 2012 | 09:08 PM
KaylaAnn's Avatar
squeal similar to a short stop, if the noise is still there after the alignment where should I look next?
Old Apr 26, 2012 | 09:13 PM
Potenza's Avatar
You should always get an alignment directly after any suspension geometry change. You probably have excessive toe out since you lowered the car.
Old Apr 26, 2012 | 09:25 PM
punx45's Avatar
is it coming from the same spot every time?
i suppose rubbing would be the next logical step. that or the hardware in the strut top.
Old May 1, 2012 | 09:17 PM
KaylaAnn's Avatar
So guys this happened on the 27th.
I got a alignment and two new front tires and Im no longer hearing the strange sounds. THANKS for helping me out
Old May 1, 2012 | 09:21 PM
punx45's Avatar
haha funny enough i was wondering if there was an update to this thread today.. glad you got it solved !
you werent driving on tires with exposed threads were you? thats like superunsafe!
Old May 1, 2012 | 09:31 PM
KaylaAnn's Avatar
I like to live life on the edge hahah jk. Yeah I had to drive home from class like this. Needless to say it was the scariest 20 minutes of my life.
Old May 2, 2012 | 12:36 AM
Potenza's Avatar
Did you happen to get the before and after spec printout of your alignment?
Makes me wonder how far your toe was off.
Old Aug 29, 2012 | 09:53 AM
jgpoirier's Avatar
X2.
Glad you got it figured out
Old Aug 29, 2012 | 11:47 AM
Tommy C's Avatar
Important to get alignment after installing coilovers
GoFits
29
Apr 26, 2014 01:40 PM
UN_FIT
14
Mar 25, 2011 07:54 AM
Squad808 Fit
Dec 13, 2008 08:57 PM
SukebePAUr
Jul 18, 2008 09:47 AM
raton
Hawaii Community
Apr 16, 2008 07:07 AM
