Aftermarket gauges/cluster
Old Jun 1, 2012 | 10:41 PM
phasfit's Avatar
Going blind researching for aftermarket instruments/gauges. (oil press./water temp/Volts) Thought about making a pod, but not on the side trim with the air bag inside it, don't want to get clocked by a flying gauge. Anyone?
Old Jun 1, 2012 | 10:49 PM
Goobers's Avatar
I thought the oe trim was designed to not clock the driver in the event of a deployment... in that case, why not make sure it opens up the same way oe would.
Old Jun 2, 2012 | 01:54 AM
teamkitty's Avatar
I wish mugen (or anybody) made a version of their "assist meters" that was the mirror image of this to fit on LHD fits.
Scroll down past the killer recaro seats to see it here:
–³ŒÀ | Fit | PARTS | INTERIOR
Old Jun 2, 2012 | 02:09 AM
urbanoutfit's Avatar
why would you need gauges?? not like there is much power to monitor.
Old Jun 2, 2012 | 11:01 AM
hayden's Avatar
People use gauges to monitor their power? I want one of those.
Old Jun 2, 2012 | 11:24 AM
krunk13's Avatar
Only on the Veyron
Old Jun 2, 2012 | 12:28 PM
555sexydrive's Avatar
Please tell me you were joking with that post. If not, I can only shake my head and wonder WTPh?!?!
Old Jun 2, 2012 | 01:58 PM
Texas Coyote's Avatar
I think that you should check out the ScanGauge.. It has readouts for about anything that has sensors feeding info into the ECU and will also tell you what the code is for a problem that sets off the check engine light.. There are similar products being sold now that have more features... I have mine set up to show intake air temperature, ignition timing, coolant temperature and throttle position... It has numerous other readouts that take only the push of a button to access.. There is no oil pressure gauge on it though..http://www.amazon.com/s/?ie=UTF8&key...l_7lq3gndd85_b
Old Jun 2, 2012 | 03:35 PM
hayden's Avatar
This sucker just popped up on Carview today:
Relevant thread was going, so I decided to add it here.
Old Jun 2, 2012 | 04:06 PM
Dang it Hayden that stuff looks great.... They probably don't have pods like those for my GD3... The little ScanGauge on the far left is a wonderful and entertaining tool I have enjoyed using for about 3 years or a little longer... There are more costly gauges that give you acceleration ETs that would be great to get an in the ballpark tune before going to have the car dyno tuned...
Old Jun 2, 2012 | 07:49 PM
hayden's Avatar
I'm getting an ultragauge this month to mainly watch intake temps and timing advance. Will be using our ridiculously consistent summer weather patterns to experiment with different setups, and fuel () to see if the ecu will play along. I think there is a little dot that shows up on the display when the system is in closed loop too. Expecting to be disappointed. lol
MOTOMATT
21
May 15, 2021 09:04 PM
RexRacer
Jun 13, 2013 02:15 PM
faxe
Jan 18, 2013 03:25 PM
AWDturbo
Aug 21, 2009 09:49 AM
hkjazz
theljnet.com
Jan 2, 2008 12:34 PM
