anybody autoxing on swift springs?
Old Jun 18, 2012 | 11:56 AM
unfit2compete's Avatar
Right now I'm running street tyre w/h-stock pax. I've got a progress RSB and 20/50 16 Star Specs. Own my class but too much damage to front tyres. Ready to jump to STF but can't afford coilovers. I'm looking for somebody with experience with just spring upgrade. I also drive ~30k a year.
Old Jun 18, 2012 | 11:22 PM
555sexydrive's Avatar
I ran gymkhana in my old 5R at first with stock sussy and SWIFT, very first event I developed rod knock due to car pulling much more G's. Granted somewhat unrelated, just 2 Honda cars, sort of same form of motorsport (don't equate Ken Block vids to gymkhana) and SWIFT springs. I think you will like them, CoG is dropped slightly, will still have some roll, but not as pronounced as full stock. No fine tuning obviously, but the handling will be improved. Not sure about class rules in auto-x and how you will fair, but you already know you are not really beating others; beating and owning yourself in solo time events. That's how I always look at time attacks, gymkhana and auto-x. If my time is not improving each session barring extreme weather changes than I am sucking ass.
Old Jun 19, 2012 | 12:33 PM
Oh I am beating others. Mostly w/PAX(class handicap multiplier) last event 3rd overall, 1st in class, 2012 Dixie SCCA National Tour RTF class win. I am looking more at reducing body roll/tyre wear. I have plenty of experience w/autox(18yrs) and modifications and what they do. I'm looking for specific experience in a fit autocrossed with just springs and not coil overs.
Old Jun 26, 2012 | 11:23 PM
AutoXsquid's Avatar
I'm assuming you are eating up the front shoulders? How much camber are you running? What size star specs are you running? 195? 205? 215?!?
Old Jun 27, 2012 | 07:28 AM
205/50 16. Whatever is left of the factory setting after 30k+ miles. Without crash bolts, do you know how much camber is available?
Old Jun 27, 2012 | 08:15 AM
AutoXsquid's Avatar
I would try maxxing out front camber (I'm hoping for -1.5 to -1.8ish but I haven't put an alignment on it yet, maybe someone else can answer how much you can get from stock) and then 0 tow. This will help with turn-in and might solve a lot of your tire wear problems.
Why did you go with the 16" HFP size wheels? I was thinking 15" would be better because they are lighter and the smaller diameter would provide shorter "gearing" and help with acceleration. I am a little concerned about having to do a lot of 2-3 shifting with the 15" wheels but I'm use to it in the S2k.
Old Jun 28, 2012 | 11:04 PM
The BOM's Avatar
Just read the stock class rules and you CAN use camber bolts. I love the OEM ones because it's not a cam type bolt, which i've had move during the middle of an event. I currently have OEM camber bolts on my coilovers. Those should put you around -.8* to -1* camber, which is better than stock (close to none, maybe even positive) and it still won't eat your tires if you have a toe setting of 0.
Old Jun 28, 2012 | 11:10 PM
The BOM's Avatar
On my old Bilstein PSS suspension, I elongated one of the holes on the strut bracket and used the original bolts but pushed the top of the spindle in as far as possible. I achieved -1.8* on one side and -2.0* on the other. It made a big difference over the -1* I had, AND my hankooks (225/45/15) weren't getting chewed up on the shoulders
Old Jun 28, 2012 | 11:13 PM
I know they're legal. I'm just not sure about driving 30k miles a year with them.
Old Jun 28, 2012 | 11:18 PM
Stock class rules say stock size wheels. Can't even use Mugen 16x6.5in rims. Running stock 2011 sport rims 16x6 w/ black powder coating and S2000CR/1999 acura nsx black Lug nuts. Cuz I'm awesome like that!
Old Jun 29, 2012 | 11:59 AM
Do you happen to have the honda part # and price you paid?
Old Jun 29, 2012 | 12:36 PM
AutoXsquid's Avatar
This is in the suspension section 13.8 and would lead me to conclued that you could not. I'm disappoint you can only get -.8 to -1deg of camber but then again, it is a beam rear axle econo car...
B. Both the front and rear suspension may be adjusted through their designed range of adjustment by use of factory adjustment arrangements or by taking advantage of inherent manufacturing tolerances. This encompasses both alignment and ride height parameters if such adjustments are provided by the stock components and specified by the factory as normal methods of adjustment. However, no suspension part may be modified for the purpose of adjustment unless such modification is specifically authorized by the factory shop manual for non-competition purposes.
Old Jun 29, 2012 | 12:37 PM
AutoXsquid's Avatar
I was reading this on my phone and forgot you are in a GE which is 16" stock. I'm in a GD which is 15" stock.
Old Jun 29, 2012 | 07:16 PM
13.8.E.
If
offered by the manufacturer for a particular model and year, the
use of shims, special bolts, removal of material to enlarge mounting
holes, and similar methods are allowed and the resulting alignment
settings are permitted even if outside the normal specification or
range of specifications recommended by the manufacturer. If enlarging
mounting holes is specifically authorized but no material removal
limits are specified, material removal is restricted to the amount necessary
to achieve the maximum factory alignment specification.
I think this covers Honda OEM camber bolts
Old Jun 29, 2012 | 07:21 PM
I went to the dealer today and they couldn't find what I was looking for. So I really need the OEM part numbers to get them ordered and installed by next week.
Old Jun 29, 2012 | 10:21 PM
The BOM's Avatar
Ask and you shall receive!
90188-SCC-A00
You'll need 2, one for each side. They're listed as a "service" item because they're for alignment correction if it's out of spec. They're on the same damn diagram though... silly dealer
$3 a piece
PS: dailying on -1* is absolutely exceptable In fact you'll run out of center/outside tread from autoxing before you run out of inside tread from communiting (been there).
Old Jul 6, 2012 | 02:53 PM
ok, camber bolts installed and aligned. -.2* driver and -.7* passenger w/me in car. I wonder what it was before. btw, -.5* passenger side w/me not in car.
Old Jul 6, 2012 | 03:52 PM
AutoXsquid's Avatar
I guess I should have kept reading...
I got a copy of the manual and sure enough, there it was. For the GD3 the part number is:
P/N 90188-SCC-A00
and you will need 4 of them to get the full adjustment. The factory setting is 0deg. With 2 bolts you can get 0.2deg and with 4 it says you can get 0.5deg. It's not much but I'll tak it.
Did you happen to check your rear toe and camber? I know there isn't anything we can do about it but I'm just curious. The factory settings are horrible for autocrossing.
Old Jul 7, 2012 | 08:12 PM
The BOM's Avatar
I had 0.0* and +.2* stock
Old Jul 7, 2012 | 10:17 PM
So, are you going to come and teach me a lesson tomorrow?
