Please Advise - R/R Front Strut/Shock GD3
Old Jul 7, 2012 | 11:27 PM
der Mond's Avatar
Question Please Advise - R/R Front Strut/Shock GD3
The factory manual advises to use a spring compressor in the process of removing and replacing the front strut, whereas AllDataDIY.com describes a pretty simple and straightforward process of unbolting, removing and re-installing. I cannot find a strut removal thread; can anyone tell me which process to use or describe it in more detail?
Also, AllData recommends checking alignment after installation and the factory manual doesn't even mention it. Is it necessary? I'm just wanting to replace my OEM units with KYB's, no change in ride height
Old Jul 11, 2012 | 06:04 AM
Hootie's Avatar
https://www.fitfreak.net/forums/fit-...07-08-gd3.html
^ Here's a detailed DIY thread along the lines of what you need. Mind you, this is for lowering but still has the necessary information I believe you are looking for.
I personally would check alignment afterwards since replacing the struts could change your caster and camber... toe shouldn't be affected since the tie rods aren't being adjusted.
I hope this helps.
Old Jul 11, 2012 | 09:20 PM
der Mond's Avatar
Thanks, Hootie, I appreciate it!
UmmFit
Oct 18, 2014 05:13 PM
der Mond
Jul 17, 2012 11:11 PM
der Mond
Jul 11, 2012 08:41 PM
blue line
Mar 31, 2010 06:14 PM
perfor.element
Sep 1, 2008 03:25 PM
