need to do brakes, what should i do?
Old Aug 30, 2012 | 08:45 AM
xcsp800's Avatar
Hey guys. need to do the brakes in my fit finally. Im an aggressive driver and like to have fun in the car. go to track days occasionally but mostly just a daily car for me. like i said i drive aggressively. what should i do for brakes? just keep it oem or what?
Old Aug 30, 2012 | 11:11 AM
mkane's Avatar
Hawk pads IMO would be more than enough. Browse www.fastbrakes.com for eye candy
Old Aug 30, 2012 | 01:06 PM
NIGHTHAWKSI's Avatar
+1 hawk pads and stainless lines.
make sure you get teh basic hawk pads..the higher end ones are meant specifically for race applications and need to be heated up to work properly. they will squeal and not work as well if they arent.
Old Aug 30, 2012 | 01:14 PM
xcsp800's Avatar
Thanks guys. which hawk pads?
Old Aug 30, 2012 | 01:50 PM
Hawk hps.
do not get the hp plus,
Old Aug 30, 2012 | 02:05 PM
xcsp800's Avatar
Ok thanks guys. and should i just use oem rotors?
Old Aug 30, 2012 | 03:48 PM
mkane's Avatar
^^^^^^^^^^^^^^^^^Yes
Old Aug 30, 2012 | 07:22 PM
CasualFitOwner's Avatar
There are "OE-quality" rotors available for less cost. For example, Brembo discs (W0133-1784756) are around $45/each shipped.
Old Aug 31, 2012 | 10:16 AM
apexanimal's Avatar
napa blanks are good quality and inexpensive too...
Old Aug 31, 2012 | 01:43 PM
joey_fits's Avatar
Were you having trouble slowing before? Brake fade? Spongy feel? Aggressive driving doesn't kill pads. So you're lumped in the aggressive braking catagory! I drive aggressive and have 85k on original pads and rotors. Hawk pads are overkill. Good quality but if " because racecar" look into a caliper upgrade.
Old Aug 31, 2012 | 03:43 PM
Subie's Avatar
I agree. Same questions to the OP. Unless you track/auto-cross a lot, your OEM should be adequate... And unless you have a Fit on steroids, how aggressive can you get on a stock Fit anyway? And just to qualify, there is a difference between being aggressive and reckless. If I was to be aggressive in a "stock" Fit, I'd think more about improving handling rather than braking... I'd be going through gears more - upshift/downshift engine break and less of brake pedal... if I was an aggressive driver...
Functionally, you can upgrade to aftermarket pads. For looks, slotted and/or drilled rotors, braided brake lines and over-sized calipers.
If you're a brake hard, brake often-type aggressive driver, then checking and changing fluids often would be a good idea... Just my take... with a stock set-up.
stephenmarklay
16
Jul 12, 2019 02:07 PM
setter11
15
Sep 11, 2009 06:49 PM
goodyonsen
May 22, 2009 06:30 PM
slip
18
Jun 19, 2008 11:10 PM
Beerman182
Jun 27, 2005 08:22 AM
