Rear Bumper cover Crack Repair?
Old Sep 25, 2012 | 07:04 PM
I_Use_Maps_(as_in_paper)'s Avatar
Hi Ya'll, first post, major lurker for the last few years. Lots of great stuff, hoping to contrib in the future... until then...
I Have a small ~ 4cm vertical crack on the outside of my rear bumper cover on top of where the right bracket connects to it on the inside. Any suggestions for keeping it from running, sealing it, or cleaning it up so it's not as visible somehow?
Ideally I'd like to stop a run AND make it less visible.
Model: 2009 Sport AT no Nav Billet Silver
oh, and I have some touch up paint btw but you can't see anything that's not silver.
Last edited by I_Use_Maps_(as_in_paper); Sep 26, 2012 at 11:21 AM. Reason: cleaning post
Old Sep 25, 2012 | 07:27 PM
fujisawa's Avatar
I would definitely try google on this one, but I would guess some sort of adhesive or bonding compound would be the way to go, probably applied from behind. There isn't a whole lot you can do about the appearance of the crack short of fixing it and then repainting, but you can probably stop it from getting bigger every time you push the bumper.
Old Sep 26, 2012 | 11:19 AM
Thanks fujisawa, usually i don't like the response 'google it'.Not least of which b/c I don't use google, due to policies/politics/privacy. I use ixquick.com (private search engine, that also offers anyonymous google results for those that really need google). I guess I was hoping to find someone that had 'done it before' and could give specific advice to the parameters my model of fit falls within. However, I may just become that person myself! (So, thanks for the nudge! Happy to contrib!)
So here's the most useful stuff I've found so far:
This article:
How to Repair your Plastic Bumper - Car Craft Magazine
Refers to a website that is now defunct:
urethanesupplycompany.com
as having a good guide for IDing your type of plastic to get the correct materials.
However, all is not lost, as they have a super low resolution image from that website (urethanesupply)in their article, that is just barely eligible to the dedicated reader.
Here it is:
http://image.carcraft.com/f/howto/17..._supply_co.jpg
I'm going to try to:
1) ID the plastic for my model of Fit
2) Use that guide (the image above) as a starting point
3) Attempt to get the correct materials for under ~50USD
4) Fix it myself w/o deforming/cutting/melting excessively the bumper cover and sanding the *** out of it like some people on the web are doing or using ~200 dollar Plastic Air Welding Tool. Also, I don't have a pneumatic paint gun, nor want to buy one.
Will Report back with progress on those steps! (and maybe some images too!)
Old Sep 26, 2012 | 12:00 PM
NIGHTHAWKSI's Avatar
use a solder iron to melt the bumper together at crack
fill with body filler, as minimally as possible. id suggest flexible body filler or else it can/will crack
sand said body filler once dry
paint
Old Sep 27, 2012 | 03:50 PM
just get the bandaid stickers. fixed.
Old Sep 28, 2012 | 03:08 PM
sean5995's Avatar
plasti dip it!
Akiod
Aug 8, 2016 11:15 PM
R3born
Jul 28, 2015 03:38 PM
Rebmo
Jul 2, 2015 03:57 PM
The111
Aug 11, 2010 05:13 PM
bostonmichael
Jun 6, 2008 08:24 AM
